FXO lines in trunkgroup not working
I have 2 FXO lines in one trunkgroup. But once  call on one line then at the same time i cant make second call. I dont know this DSP problem or trunkgroup problem.
RT-KW-SAN-OFF#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 23.8.0
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 7
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 30, reserved credits: 0
    Signaling channels allocated: 2
    Voice channels allocated: 0
    Credits used: 0
  Group: FLEX_GROUP_XCODE, complexity: MEDIUM
    Shared credits: 0, reserved credits: 210
    Transcoding channels allocated: 0
    Credits used: 0
dsp 2:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 240
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 2
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
9 DSP resource allocation failure
RT-KW-SAN-OFF#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FCZ1201716X
NAME: "2nd generation two port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port FXO voice interface daughtercard"
PID: VIC2-2FXO         , VID: V02 , SN: FOC15021D4S
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC14307JZJ
Router Errors while loggoing.
%VOICE_IEC-3-GW: VTSP: Internal Error (DSP unknown failure): IEC=1.1.182.9.22.13 on callID 75
*Jul 16 11:21:02.862: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: FXO lines in trunkgroup not working
Looking at your details and after using the dsp calculator..it showed that you have enough dsp resources for the resources you are using even though the gateway is saying otherwise. I will suggest that you reduce your transcoding session to 6 and test again.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Can you send us a sh run of your gateway and a show diag. Please attach them to the thread
Please find attached files as requested. Thanks
VIP Super Bronze
351
