Community Member
FXO not accepting digits
Dear all
THis is an extremly urgent issue and need to be resolved asap.
I have a IPT network with CCM 4.2,Cisco Unity Connection 1.2,Voice Gateway 2821 with FXO ports.
here is the call flow,
The user calls from outside is directed to CCM route point 9001 which directs the call to unity call handler
acting as IVR .
Now the problem i am having is that if somebody calls from outside and the IVR is played asking the
user to input the digits ,if the user presses an extension the IVR continues to play and the digits are not accepted.
Now why are the digits not accepted ??? and if continue to press numbers some of the time the IVR says u have
dialed incorrect extension.But basically it is not accepting digits.
VERY IMP Thing: This is only happening when i am calling from a land line
if i call from any mobile network to IPT network ,it never happens and everything works perfect.IVR is ok and extension dialing
is ok.
I am attaching the config of my gateway .Please have a look .May be i am missing some commands.
Nouman Khan
Community Member
Re: FXO not accepting digits
Hi Nouman
try to add this command under the voip dial-peer that is pointing to the call manager.
dtmf-relay h245-signal h245-alphanumeric
