Community Member
FXO not disconnecting after AA picksup
hi all,
I have a CCME10 with ISR2911.
Incoming calls to AA keeps ringing even when caller hangs up the call. I have no issue if it is a direct incoming call to extension(connection plar opx).
Is there any way i can get the call to disconnect correctly with AA?
I tired using "supervisory disconnect anytone" on the voice-port 0/0/0 solved my problem, BUT it messed up my outgoing call. Outgoing call only rang once, then it gets cut off
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone DST
caller-id enable
service aa flash:app-b-acd-aa-
  paramspace english index 1
  param number-of-hunt-grps 2
  param handoff-string aa
  param dial-by-extension-option 1
  paramspace english language en
  param aa-pilot 6000
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt
  param call-retry-timer 15
  param voice-mail 6000
  param max-time-call-retry 700
  param service-name queue
service queue flash:app-b-acd-
  param queue-len 10
  param aa-hunt3 3333
  param number-of-hunt-grps 1
  param aa-hunt2 2222
  param queue-manager-debugs 1
dial-peer voice 3000 pots
service aa
incoming called-number 6000
port 0/0/0
forward-digits all
This looks like FXO disconnect problem to me:
If you successfully find your disconnect tones for your country I think that your AA is going to work fine also...
HTH, Dragan
Community Member
hi there, thanks for your info
I did follow the link and recorded and found out the frequency for busy and disconnect tone, however that did not solve my problem.
Still having the same issue.
Calls will only cut off when the operator picks up the ever ringing call and ends it.
