12-07-2009 03:01 PM - edited 03-15-2019 08:42 PM
Is there any way to have my FXO port disconnect after a certain time limit? I have calls staying up for over 1 hour and I want them to die after 30 minutes. Can I do this with an FXO port?
Cheers!
Dave
12-07-2009 10:09 PM
It is a common problem with loop start signalling. Can you try to use ground start signaling rather than loop start signalling and see whether it help ?
thanks.
12-08-2009 06:00 AM
I'm not sure if this is what you are asking for - this applies to a situation where someone hangs up and
the FXO port does not disconnect - try the following commands -
voice-port x/x/x
supervisory disconnect dualtone mid-call
timeouts call-disconnect 1
timeouts wait-release 1
timing guard-out 500
shut
no shut
HTH,
Art
12-08-2009 07:35 AM
Please also look at
document http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Hope this helps
Alex
12-08-2009 07:56 AM
What I am trying to acomplish in this one is I want any call to drop after 30 minutes. Basically I want a timer, that says after 30 minutes where someone is still chatting away or not, drop the call, close the FXO port.
Cheers!
Dave
12-08-2009 08:06 AM
12-08-2009 08:32 AM
Thanks for the comments, but what is the actual command?
Also I am not using a Call Manager here, so not sure if it will apply.
Cheers!
Dave
12-08-2009 08:35 AM
Sorry, that is a CCM service parameter. I know of no IOS command that will disconnect
an FXO port after a certain call duration.
Anyone else?
Good Luck!
Art
