FXO Not disconnecting
Is there any way to have my FXO port disconnect after a certain time limit?  I have calls staying up for over 1 hour and I want them to die after 30 minutes.  Can I do this with an FXO port?
Cheers!
Dave
Re: FXO Not disconnecting
  It is a common problem with loop start signalling. Can you try to use ground start signaling rather than loop start signalling and see whether it help ?
thanks.
Silver
I'm not sure if this is what you are asking for - this applies to a situation where someone hangs up and
the FXO port does not disconnect - try the following commands -
voice-port x/x/x
supervisory disconnect dualtone mid-call
timeouts call-disconnect 1
timeouts wait-release 1
timing guard-out 500
shut
no shut
HTH,
Art
Green
Please also look at
document http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
What I am trying to acomplish in this one is I want any call to drop after 30 minutes.  Basically I want a timer, that says after 30 minutes where someone is still chatting away or not, drop the call, close the FXO port.
Cheers!
Dave
Silver
This Service Parameter will do what you want - but it is global....
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
This is a required field.
Default:  720
Minimum:  0
Maximum:  35791
Unit: min
Thanks for the comments, but what is the actual command?
Also I am not using a Call Manager here, so not sure if it will apply.
Cheers!
Dave
Silver
Sorry, that is a CCM service parameter.  I know of no IOS command that will disconnect
an FXO port after a certain call duration.
Anyone else?
Good Luck!
Art
560
