FXO not disconnection
Dear All
I need an urgent help
I’m using CME Ver 8.6 and unity express running on sm-sre-710-k9   at Saudi Arabia
If someone call our land line, call redirect to auto attendant if only no one answer, EXT keep ringing and fxo port stay on
voice class custom-cptone 2
dualtone disconnect
  frequency 425
  cadence 500 500
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone 2
cptone BR
timeouts call-disconnect 0
connection plar opx xxx
caller-id enable
Re: FXO not disconnection
this is a well known issue in FXO setup. the disconnect signal it depends on the PBX you are connected from PSTN provider. the disconnect signals are different from one vendor to other, Ericson, Siemens, Alcatel,... etc.
You need to take the appropriate disconnect signal from your PSTN provider if it is possible.
you can use the following link to look for your current disconnect signal
http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=92&kTone=10
if one of the above is not working you need to take pcm captures, find the below link
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
to take pcm capture use the following command
1. Enable the capture:
    Router(config t)#voice hpi capture buffer 5000000
    Router(config t)#voice hpi capture destination flash:FileName.pcm.dat
2. Start the capture:
    Router#test voice port x/y/z pcm-dump caplog 7
3. Place a call on that port, and disconnect from the far end.
4. After the call has been disconnected from the PSTN side, disable the capture with the command below.
   Be sure to do this, or otherwise the router flash will be full and the router will hang.
   Router#test voice port x/y/z pcm-dump disable
   Router(config t)#no voice hpi capture destination
5. Please send me this .dat file with the bad capture so I can extract it into PCM audio files.
Anas
please rate all helpful posts
Hi Ismaeel,
also take a look for the following thread
https://supportforums.cisco.com/message/3883674#3883674
Anas
please rate all the helpful posts
Did u get a solution? facing
Did u get a solution? facing same problem now. really appreciate your help. :)
voice class custom-cptone STC
 dualtone disconnect
  frequency 398
  cadence 502 497
sorry i was out
346
