FXO OUT GOING CALL ISSUE CCME
Hi Team
We have 7 PSTN line and two VIC-2-FXO module every thing configuration finished but the problem  at a time only outgoing call two line
 Two number only going out another number not working every time
0114981800
0114980490
My cme configuration file please check
CME#sh run
Building configuration...
Current configuration : 32317 bytes
! Last configuration change at 15:54:06 UTC Sat Oct 11 2014
! NVRAM config last updated at 15:54:27 UTC Sat Oct 11 2014
version 15.3
hostname LCC-SIPOREX-CME
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
enable password admin
no aaa new-model
clock timezone UTC 3 0
ip cef
ip dhcp excluded-address 192.1.1.1 192.1.1.109
ip dhcp excluded-address 192.1.1.200 192.1.1.255
ip dhcp pool 1
 network 192.1.1.0 255.255.255.0
 default-router 192.1.1.111
 option 150 ip 192.1.1.111
 dns-server 192.1.1.104
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
trunk group fxo
 voice-class cause-code 1
 hunt-scheme longest-idle
trunk group SIPOREX
 description "Local landline numbers"
 hunt-scheme random
crypto pki trustpoint TP-self-signed-1480474283
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1480474283
 revocation-check none
 rsakeypair TP-self-signed-1480474283
crypto pki certificate chain TP-self-signed-1480474283
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343830 34373432 3833301E 170D3132 30383037 31303231
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34383034
  37343238 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CE31 54464708 8BC3C22D 347D958E 3AE36BBC 16C56FA2 BD8290E5 D732A779
  FA3EFE94 CB157EA8 2F6BB3AB 7993733A 5F74188B 46D1420C FF20223D 33807E92
  667FE112 C93EF28F 60F4695D 821128CD 82A4B33E 53F15888 BC2B16E3 3CAB0B31
  6DEF8109 882CC001 E5098472 721ABAE2 D2A458E7 E16716AA C3D5723D 38E55222
  62170203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1477083B A9425D93 CCEB3715 1B69E262 F618B88E 16301D06
  03551D0E 04160414 77083BA9 425D93CC EB37151B 69E262F6 18B88E16 300D0609
  2A864886 F70D0101 05050003 8181007D 071BDAD1 7A89C0D2 54382FCB 74881C0E
  524784C5 972E41CA 0CF827D4 8523F08D EDB74400 FD493D5D 6EDE52B2 A8D68A09
  20490C72 C9B21662 770B5B94 0B96A360 B83B20E7 5295A1AF C0A44518 0B022122
  A666CBBF B803B8CD CB183A28 4E261E71 823DCF69 D185892E 57DA8B3A BE22EDA5
  E7CA8354 9504B0F0 A8AE5F16 0D6329
        quit
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  registrar server expires max 300 min 60
voice class codec 1
 codec preference 1 g711ulaw
voice class custom-cptone STC
 dualtone disconnect
  frequency 425
  cadence 250 250
voice register global
 mode cme
 source-address 192.1.1.111 port 5060
 max-dn 40
 max-pool 20
 load 8961 sip8961.9-2-2SR1-9.loads
 authenticate register
 authenticate realm all
 timezone 31
 mwi reg-e164
 voicemail 999
 tftp-path flash:
 create profile sync 0005461448220093
 camera
 video
voice register dn  1
 number 0
 call-forward b2bua noan 999 timeout 20
 allow watch
 name Operator
 label Operator
voice register template  1
 feature-button 1 GpickUp
 feature-button 2 Trnsfer
 softkeys hold  Newcall Resume iDivert
 softkeys idle  Newcall DND Gpickup Cfwdall Redial
 softkeys seized  Redial Endcall Gpickup Meetme
 softkeys connected  Endcall Park iDivert Confrn Hold Trnsfer
voice register pool  1
 id mac 1CAA.0710.0AC1
 type 8961 addon 1 CKEM
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte sip-kpml sip-notify
 username cisco password cisco
 codec g711ulaw
 no vad
 camera
 video
 blf-speed-dial 1 242 label "Mr.Mohd_Al_Hathlol_(GM)"
 blf-speed-dial 2 222 label "Mr.Abdul_Aziz_Al_Oraini"
 blf-speed-dial 3 231 label "Mr.Dr.Kamal"
license udi pid CISCO2921/K9 sn FCZ163270CP
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
username admin privilege 15 password 0 julay102008
redundancy
interface Loopback0
 ip address 172.16.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 192.1.1.111 255.255.255.0
 duplex auto
 speed auto
interface ISM0/0
 ip unnumbered Loopback0
 service-module ip address 172.16.1.2 255.255.255.0
 !Application: CUE Running on ISM
 service-module ip default-gateway 172.16.1.1
interface GigabitEthernet0/1
 ip address 192.168.1.159 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 description Internal switch interface connected to Internal Service Module
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/GUI
ip route 172.16.1.2 255.255.255.255 ISM0/0
tftp-server flash:sip8961.9-2-2SR1-9.loads
tftp-server flash:xml-test.html
tftp-server flash:home.shtml
tftp-server flash://172.16.1.1/ccme.html
tftp-server html
tftp-server flash:/GUI
control-plane
voice-port 0/0/0
 trunk-group SIPOREX
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone STC
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts interdigit 2
 timeouts call-disconnect 3
 timeouts ringing 5
 timeouts wait-release 3
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/0/1
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/0/2
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/0/3
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/0
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/1
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/2
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/3
 trunk-group SIPOREX
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/2/0
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/1
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/2
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/3
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.1.111 identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register conference
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 3
 associate application SCCP
 shutdown
dial-peer cor custom
 name internal
 name local
 name national
 name mobile
 name international
dial-peer cor list internal
 member internal
dial-peer cor list local
 member local
dial-peer cor list national
 member national
dial-peer cor list mobile
 member mobile
dial-peer cor list international
 member international
dial-peer cor list Restricted
 member internal
dial-peer cor list LocalCalls
 member internal
 member local
dial-peer cor list LongDistance
 member internal
 member local
 member national
 member mobile
dial-peer cor list International
 member internal
 member local
 member national
 member mobile
dial-peer voice 666 voip
 description " Dial-Peer for CUE VM "
 destination-pattern 999
 session protocol sipv2
 session target ipv4:172.16.1.2
 dtmf-relay h245-alphanumeric h245-signal rtp-nte sip-notify
 codec g711ulaw
 no vad
dial-peer voice 101 voip
 description " Dial-Peer for CUE AA"
 destination-pattern 888
 codec g711ulaw
 no vad
dial-peer voice 3 pots
 trunkgroup SIPOREX
 corlist outgoing mobile
 destination-pattern 905[056].......
 prefix 05
dial-peer voice 4 pots
 trunkgroup SIPOREX
 corlist outgoing national
 destination-pattern 90[234679].......
 prefix 0
dial-peer voice 5 pots
 trunkgroup SIPOREX
 corlist outgoing international
 destination-pattern 900T
 prefix 00
dial-peer voice 6 pots
 trunkgroup SIPOREX
 corlist outgoing local
 destination-pattern 9600T
 prefix 600
dial-peer voice 7 pots
 trunkgroup SIPOREX
 destination-pattern 9800T
 prefix 800
dial-peer voice 20 pots
 trunkgroup SIPOREX
 destination-pattern 9200T
 prefix 200
dial-peer voice 21 pots
 trunkgroup SIPOREX
 corlist outgoing LongDistance
 destination-pattern 905T
 prefix 05
dial-peer voice 22 pots
 trunkgroup SIPOREX
 destination-pattern 904T
 prefix 04
dial-peer voice 23 pots
 trunkgroup SIPOREX
 destination-pattern 908T
 prefix 08
dial-peer voice 24 pots
 trunkgroup SIPOREX
 destination-pattern 909T
 prefix 09
dial-peer voice 1 pots
 trunkgroup SIPOREX
 destination-pattern 9[19]..
 forward-digits 3
dial-peer voice 2 pots
 trunkgroup SIPOREX
 destination-pattern 9[2-8][0-9][1-9]....
 forward-digits 7
dial-peer voice 53 pots
 trunkgroup SIPOREX
 description " Mobile numbers"
 destination-pattern 905........
 forward-digits 10
dial-peer voice 52 pots
 trunkgroup SIPOREX
 description "National lanline numbers"
 destination-pattern 901[1-4,6,7].......
 forward-digits 10
dial-peer voice 51 pots
 trunkgroup SIPOREX
 destination-pattern 9[2,6]......
 forward-digits 7
presence
 presence call-list
sip-ua
 presence enable
gatekeeper
 shutdown
telephony-service
 sdspfarm units 3
 sdspfarm tag 1 conference
 conference hardware
 conference transfer-pattern
 video
 no auto-reg-ephone
 max-ephones 100
 max-dn 250
 ip source-address 192.1.1.111 port 2000
 system message LCC_SIPOREX
 time-zone 31
 date-format dd-mm-yy
 voicemail 999
 mwi reg-e164
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$qHe3$xblvRD1ouV4jr8RcGUiMM.
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 221
 description Mr. Yassir
 name Mr. Yassir
 call-forward busy 999
 call-forward noan 999 timeout 15
 corlist incoming LongDistance
ephone-dn  2  dual-line
 number 222
 description Mr.Abdul Aziz Al Oraini
 name Mr.Abdul Aziz Al Oraini
 call-forward noan 999 timeout 10
ephone-dn  3  dual-line
 number 223
 description Mr.Shakir.Mohd
 name Mr.Shakir.Mohd
ephone-dn  5  dual-line
 number 225
 description Cashier
 name Cashier
 corlist incoming Restricted
Any thing more configuration Please update ASNP
Thank ypu
I think you have 3 modules
I think you have 3 modules  VIC-4-FXO
regarding your question
disconnect all phone line from router, then connect to analog phone and make calls.
so check all lines incoming and outgoing direction
and share
sh inv
sh dial-peer voice summ
 Hi Tagir TemirgaliyevThanks
Thanks your replay
yes we have checked  all the line using analog phone and found all the lines are working well.
Please check show inventory and sh dial-peer voice summary
-CME#show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FCZ163270CP, Hw Revision: 1.0"
PID: CISCO2921/K9      , VID: V06 , SN: FCZ163270CP
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC16082G9G
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC15125X10
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC16082GM5
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC162918V0
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9    , VID: V02 , SN: FOC162427QV
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V03 , SN: DCA1619K0N9
LCC-SIPOREX-CME#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT
PORT    KEEPALIVE
666    voip  up   up             999                0  syst ipv4:172.16.1.2
101    voip  up   up             888                0  syst ipv4:172.16.1.2
3      pots  up   up   05        905[056].......    0                      up
trunkgroup SIPOREX
4      pots  up   up   0         90[234679]......-  0                      up
trunkgroup SIPOREX
5      pots  up   up   00        900T               0                      up
trunkgroup SIPOREX
6      pots  up   up   600       9600T              0                      up
trunkgroup SIPOREX
7      pots  up   up   800       9800T              0                      up
trunkgroup SIPOREX
20     pots  up   up   200       9200T              0                      up
trunkgroup SIPOREX
21     pots  up   up   05        905T               0                      up
trunkgroup SIPOREX
22     pots  up   up   04        904T               0                      up
trunkgroup SIPOREX
23     pots  up   up   08        908T               0                      up
trunkgroup SIPOREX
24     pots  up   up   09        909T               0                      up
trunkgroup SIPOREX
1      pots  up   up             9[19]..            0                      up
trunkgroup SIPOREX
2      pots  up   up             9[2-8][0-9][1-9]-  0                      up
trunkgroup SIPOREX
53     pots  up   up             905........        0                      up
trunkgroup SIPOREX
52     pots  up   up             901[1-4,6,7]....-  0                      up
trunkgroup SIPOREX
51     pots  up   up             9[2,4,6]......     0                      up
trunkgroup SIPOREX
20001  pots  up   up             221$               0
50/0/1
20002  pots  up   up             227$               0
50/0/2
             AD                                    PRE PASS                OUT
PORT    KEEPALIVE
20003  pots  up   up             223$               0
50/0/3
20004  pots  up   up             225$               0
50/0/5
20005  pots  up   up             226$               0
50/0/6
20006  pots  up   up             243$               0
50/0/7
20007  pots  up   up             228$               0
50/0/8
20008  pots  up   up             229$               0
50/0/9
20009  pots  up   up             231$               0
50/0/10
20010  pots  up   up             232$               0
50/0/11
20011  pots  up   up             233$               0
50/0/12
20012  pots  up   up             234$               0
50/0/13
20013  pots  up   up             235$               0
50/0/14
20014  pots  up   up             236$               0
50/0/15
20015  pots  up   up             237$               0
50/0/16
20016  pots  up   up             240$               0
50/0/19
20017  pots  up   up             241$               0
50/0/20
20018  pots  up   up             265$               0
50/0/21
20019  pots  up   up             333$               0
50/0/22
20020  pots  up   up             244$               0
50/0/23
20021  pots  up   up             245$               0
50/0/24
20022  pots  up   up             246$               0
50/0/25
20023  pots  up   up             247$               0
50/0/26
             AD                                    PRE PASS                OUT
PORT    KEEPALIVE
20024  pots  up   up             248$               0
50/0/27
20025  pots  up   up             249$               0
50/0/28
20026  pots  up   up             266$               0
50/0/29
20027  pots  up   up             251$               0
50/0/30
20028  pots  up   up             253$               0
50/0/31
20029  pots  up   up             254$               0
50/0/32
20030  pots  up   up             255$               0
50/0/33
20031  pots  up   up             256$               0
50/0/34
20032  pots  up   up             257$               0
50/0/35
20033  pots  up   up             258$               0
50/0/36
20034  pots  up   up             259$               0
50/0/37
20035  pots  up   up             264$               0
50/0/38
20036  pots  up   up             262$               0
50/0/40
20037  pots  up   up             263$               0
50/0/41
20038  pots  up   up             264$               0
50/0/42
20039  pots  up   up             242$               0
50/0/43
20040  pots  up   up             250$               0
50/0/44
20041  pots  up   up             267$               0
50/0/45
20042  pots  up   up             284$               0
50/0/46
20043  pots  up   up             269$               0
50/0/47
20044  pots  up   up             270$               0
50/0/48
             AD                                    PRE PASS                OUT
PORT    KEEPALIVE
20045  pots  up   up             271$               0
50/0/49
20046  pots  up   up             272$               0
50/0/50
20047  pots  up   up             273$               0
50/0/51
20048  pots  up   up             274$               0
50/0/52
20049  pots  up   up             277$               0
50/0/53
20050  pots  up   up             278$               0
50/0/54
20051  pots  up   down                              0
50/0/55
20052  pots  up   up             280$               0
50/0/56
20053  pots  up   up             281$               0
50/0/57
20054  pots  up   up             239$               0
50/0/58
20055  pots  up   up             279$               0
50/0/65
20056  pots  up   up             268$               0
50/0/71
20057  pots  up   up             A00$               0
50/0/80
20058  pots  up   up             A00$               1
50/0/81
20059  pots  up   up             A00$               2
50/0/82
20060  pots  up   up             A00$               3
50/0/83
20061  pots  up   up             A00$               4
50/0/84
20062  pots  up   up             A00$               5
50/0/85
20063  pots  up   up             A00$               7
50/0/86
20064  pots  up   up             A00$               7
50/0/87
40002  voip  up   up             0$                 0  syst ipv4:192.1.1.153:506
             AD                                    PRE PASS                OUT
PORT    KEEPALIVE
60     pots  up   up             99200.....         0                      up
trunkgroup SIPOREX
61     pots  up   up             9800.......        0                      up
trunkgroup SIPOREX
62     pots  up   up             990.               0                      up
trunkgroup SIPOREX
63     pots  up   up             99200......        0                      up
trunkgroup SIPOREX
at a time only two call going outside  please update ASNP
Thank you
Hi all  Please any update....
Hi all
Please any update........
160
