FXO outgoing call problem
HI
I have a new installtion for a new site , i have Cisco gateway 3925 with 4 VIC2-4 fxo cards and a CUCM v8.5. I used MGCP between Cisco Gateway and CUCM. When i started to do test for outgoing and incoming calls , i found the below:-
1- For outgoing call i tried to call  from Cisco IP phone to my mobile number  , on Cisco IP phones it gives me ring out then connected however my mobile still ringging.
2-For incoming , i have a disconnect problem.
I have already read all documents and tried the below document without any success.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Can you paste your GWs config?
Yosh
HTH Regards, Yosh
hi
Thanks for your reply , i need to inform you that i have already added under ports " cptone , input , custom-phone" and try all methods and still have the same issue:-
Even on CUCM , i configured ports "loop & ground" with the same results:-
can you find the below:-
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager switchback immediate
ccm-manager redundant-host 10.20.20.3
mgcp
mgcp call-agent 10.20.20.2 service-type mgcp version 0.1
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
dial-peer voice 104 pots
service mgcpapp
port 0/1/0
no shu
dial-peer voice 105 pots
service mgcpapp
port 0/1/1
no shu
dial-peer voice 106 pots
service mgcpapp
port 0/1/2
no shu
dial-peer voice 107 pots
service mgcpapp
port 0/1/3
no shu
dial-peer voice 108 pots
service mgcpapp
port 0/2/0
no shu
dial-peer voice 109 pots
service mgcpapp
port 0/2/1
no shu
dial-peer voice 110 pots
service mgcpapp
port 0/2/2
no shu
dial-peer voice 111 pots
service mgcpapp
port 0/2/3
no shu
dial-peer voice 112 pots
service mgcpapp
port 0/0/0
dial-peer voice 113 pots
service mgcpapp
port 0/0/0
dial-peer voice 114 pots
service mgcpapp
port 0/0/0
I hope to check the below debug for incoming call , as you see there is no incoming caller id :-
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  4 15:38:21.190: //-1/35F714788165/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x13E235E4, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=110, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Feb  4 15:38:21.190: //-1/35F714788165/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  4 15:38:21.190: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  4 15:38:21.194: :cc_get_feature_vsa malloc success
Feb  4 15:38:21.194: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  4 15:38:21.194:  cc_get_feature_vsa count is 1
Feb  4 15:38:21.194: :FEATURE_VSA attributes are: feature_name:0,feature_time:338316488,feature_id:99
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/cc_process_call_setup_ind:
   Event=0x13DD9428
   >>>>CCAPI handed cid 102 with tag 110 to app "MGCPAPP"
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/ccCallSetContext:
   Context=0x1429A340
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/ccCallSetupAck:
   Call Id=102
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/ccCallModify:
   Nominator=0x1, Params=0x2237938, Call Id=102
Feb  4 15:38:21.194: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x1A80ABC, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb  4 15:38:21.194:  cc_get_feature_vsa count is 2
Feb  4 15:38:21.194: :FEATURE_VSA attributes are: feature_name:0,feature_time:338315144,feature_id:100
Feb  4 15:38:21.194: //103/35F714788165/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Feb  4 15:38:21.194: //103/35F714788165/CCAPI/ccCallSetContext:
   Context=0x1429A130
Feb  4 15:38:21.194: //102/35F714788165/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x13E235E4, Call Id=102
Feb  4 15:38:21.194: //103/35F714788165/CCAPI/cc_api_call_connected:
   Interface=0x1A80ABC, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/ccConferenceCreate:
   (confID=0x2237E34, callID1=0x67, gcid=0-0-0-0, tag=0x0)
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccConferenceCreate:
   (confID=0x2237E34, callID2=0x66, gcid=35F71478-8CE911E3-8165CDC3-2200ABF7, tag=0x0)
   Conference Id=0x2237E34, Call Id1=103, Call Id2=102, Tag=0x0
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x1A80ABC, Source Call Id=103,
   Destination Call Id=102, Disposition=0x0, Tag=0x0
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x13E235E4, Source Call Id=102,
   Destination Call Id=103, Disposition=0x0, Tag=0xFFFFFFFF
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x12, Destination Call Id=102)
   Call Entry(Conference Id=0x12, Destination Call Id=103)
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_caps_ind:
   Destination Interface=0x1A80ABC, Destination Call Id=103, Source Call Id=102,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_api_caps_ind:
   Destination Interface=0x13E235E4, Destination Call Id=102, Source Call Id=103,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2695)
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_caps_ack:
Feb  4 15:38:21.198: //103/35F714788165/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x12, Call Id1=103, Call Id2=102
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_voice_mode_event:
   Call Id=102
   Call Entry(Context=0x1429A340)
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=102
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccCallReportDigits:
   (callID=0x66, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=102
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x13E235E4, callID=0x66, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x13E235E4, Call Id=102
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x2237778, Call Id=102
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/cc_api_call_modify_done:
Feb  4 15:38:21.198: //102/35F714788165/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
Have you done a "no mgcp" wait for the teadown and then "mgcp"?
Yosh
HTH Regards, Yosh
HI
yes of course many times no mgcp then mgcp , some thing is very strange . Any idea.
thanks
Has this issue been resolved?
Yosh
HTH Regards, Yosh
Bronze
Please share below mentioned debug
debug vpm signal
debug mgcp packet
debug voip ccapi inout
It will help us in finding out cause of disconnect
Mohit Singh
230
