FXO Plar ring time & TCL script for playing announcements
Hi all,
I have two questions regarding playing a plain announcement through an fxo port.
First of all, by default, fxo port opens after 2 rings, i want the port to open as soon as the line starts ringing, but couldn't make it happen. (ring number command, plar / plar opx commands didn't work)
The second question is, how can i play an announcement through this fxo port and disconnect the call? Do you have a simple TCL script that can do this?
Kind Regards,
Baris.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: FXO Plar ring time & TCL script for playing announcements
You'rewlecome, please remember to rate useful posts with the scrollbox below.
1. do you have caller-id enabled ?
2. see disconnect script thta I wrote:
http://pbevila.fastmail.fm/public
Hi Paolo,
1. yes it was enabled, right after disabling it, the ring duration dropped to one ring.
2. i'm going to test it in my lab, and write back.
Thanks for the valuable information that you've provided.
Baris.
sure thing. Thanks.
245
