02-10-2008 09:43 PM - edited 03-15-2019 08:44 AM
Dear Pros,
can you check this? I can see the FXO card through the sh ver but I cannot get to the port to configure it. This is mostly an IOS issue, but I want to make sure of it because the IOS is 4.0 enterprise, which I though support voice and this router is so critical which I don't want to take the chance to miss with it.
Sh Ver
Cisco 2821 (revision 53.51) with 1036288K/12288K bytes of memory.
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
R100-International(config)#dial-peer voice 7 pots
R100-International(config-dial-peer)#des
R100-International(config-dial-peer)#dest
R100-International(config-dial-peer)#destination-p
R100-International(config-dial-peer)#destination-pattern 3....
R100-International(config-dial-peer)#dir
R100-International(config-dial-peer)#direct-inward-dial
R100-International(config-dial-peer)#port ?
% Unrecognized command
swami
02-11-2008 02:20 AM
Hi, most likely you do not have the necessary DSP modules in the router, do "show diag" to know. You should see PVDM2-xx without it you canno have the voice port to work.
02-14-2008 04:27 AM
Dear,
My customer looking for the supporting documents.Where can we find it?
Swami
02-14-2008 05:21 AM
