FXO port connectivity
Hi All,
How can i point a Route Pattern to multiple FXO port to use, I have configured 2 FXO ports (H.323) but when i try to call it uses only the 1st FXO, when any calls lands on 2nd FXO it waits for some time and it drops the call,
Both the ports has similer configuration.
Jal
  • IP Telephony
1 REPLY
Re: FXO port connectivity
Verison of Call Manager?
Are the FXO ports registered?
Do you have 1MB's plugged into the FXO ports.
did you recreate certain Route Group, Route List and then create your route pattern to use that certain RL and RG
116
