Bronze
FXO PORT COUNT
Guys,
just a simple question. We have a customer that requires 80 Analogue PSTN trunks to be terminated and im trying to see what other options there are other that multiple routers and the HDA-6FXO= along with the Network modules.
Are there any options for a 4500 switch that would be able to handle this?
P.S they are sticking with this an not converting to Digital.
thanks in advance
Hall of Fame Super Gold
Re: FXO PORT COUNT
There is no single Cisco product that can host that many analog CO lines.
Why? Because anybody that needs that many lines, goes digital: cheaper, more robust, more features.
By the way, everytime I work on a system using analog, there are problems, every single time.
But you said they don't want that.
So you better choice is using either a channel bank, or a multiport FXO/FXS converter, live with the additional cost and cumbersomeness.
Bronze
Re: FXO PORT COUNT
Beleive me when i say i agee 100% with what youre saying. This is however a tender and the customer has stated that this MUST be a requirement.They may or may not choose to go Digital (Of which we advised) but for now i have to go with what they requested with input of the other possible options
For now Ive specified QTY 2 3845 Rtrs
EVM-HD-8FXS/DID - QTY 6
EM-HDA-6FXO - qty 11
thanks
Re: FXO PORT COUNT
Check channel banks or multiport FXS/FSO converters, I'm afraid that is the only way to stay competitive using Cisco in a tender, others will propose anybrand VGs and may have an edge over your bid.
187
