FXO port disconect problem
I met  problem when FXO port on cisco router can`t get disconnect messages ,because of it cisco ip phone remains ringing.
When dialing from ip phone ,it begins to call after 15-20 seconds.
I have the following topology:
PSTN gives  phone connection through  SIP to Grandstream and from grandstream by FXO to Router.
I tried to make cusctom cptone,but it didn`t help me.
There is my voice port configuration :
voice-port 0/0/0
 ring number 2
 groundstart auto-tip delay 1
 echo-cancel coverage 64
 no vad
 timing hookflash-out 50
 timing guard-out 3000
 caller-id enable
voice-port 0/0/1
 ring number 2
 no battery-reversal
 signal groundStart
 caller-id enable
Also i try to discover from Telco which cptone ,frequency,cadence, grandsteam h 502 use ,and got answer that Telco engineers don`t know ,they staied it by default.In grandstream datasheets i also couldn`t find any usefull information
Everyone's tags (3)
1 REPLY
VIP Gold
Put below command under voice
Put below command under voice ports then check please.
timeouts call-disconnect 2
and you can visit below discussions for more info.
https://supportforums.cisco.com/discussion/12134091/fxo-ports-not-releasing-quickly
https://supportforums.cisco.com/discussion/11667991/fxo-not-immediately-disconnecting
Suresh
66
