Community Member
FXO port, hears 5 rings before the call is connected
Dear all,
When an incoming call rings on a Cisco 2921 FXO port, the caller hears 5 rings before the call is connected.  Does anyone know of a way to shorten or eliminate  this delay?
Please find attached the configuration and sceanario as following:
Cisco 2921 04 FXO with H323 configuration and 4 FXS with MGCP configuration.
Cisco Call Manager 8.6
Thanks you for your help.
1 ACCEPTED SOLUTION
Green
Your router is failing with a cause code 18 on dial peer 1
dial-peer voice 1 voip
preference 1
destination-pattern [1-7]...
session target ipv4:172.16.69.10
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 2 voip
preference 2
session target ipv4:172.16.69.14
codec g711ulaw
This is your preference 1 --- 1st choice
It then timesout and reties on dial peer 2 --  this is succesful.
Look for connectivity issues between the router IP address 172.16.69.18 and the call processor CCM on 172.16.69.10
May be the call manager service is not running or there is no pings etc.
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Green
You can try changing your PLAR to immediate
voice-port 0/0/0
cptone GB
connection plar opx immediate 6002
impedance 600c
station-id name PSTN
station-id number 35123497
Please be aware that this may stop the inbound CLI being presented if you need it.
Try and test
Alex
Community Member
Dear Alex,
I try your comment, but it still have no luck. Any help ?
Thanh
Hall of Fame Super Silver
Re: FXO port, hears 5 rings before the call is connected
Does it ring 5 times after hitting the GW? Or before even hitting it?
Community Member
Dear Chris,
Maybe it ring 5 times after hitting the GW because on the first ring gateway FXO Port light up.
Thành
can you post your full GW config?
Any chance there is an overlapping pattern/DN on CUCM causing interdigit timeout?
Community Member
Dear Chris,
You can find the attached file configuration in the first post above. Anyway i repost:
I had two Call Manager.
Extension range: 1xxx - 3xxx
Auto-Attendant & CTI port: 6xxx
icense udi pid CISCO2911/K9 sn FGL1601126G
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.69.18 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.69.18
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.16.69.1
control-plane
voice-port 0/0/0
cptone GB
connection plar opx 6002
impedance 600c
voice-port 0/0/1
timing hookflash-out 50
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager redundant-host 172.16.69.14
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.16.69.10
ccm-manager config
mgcp
mgcp call-agent 172.16.69.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
preference 1
codec g711ulaw
dial-peer voice 21 pots
destination-pattern .T
direct-inward-dial
port 0/0/0
forward-digits all
preference 2
codec g711ulaw
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
Your dial-peer 21 is creating an overlap thus causing the inter-digit timeout.  You need to make it something other than .T, something more explicit that does not overlap with [1-7]...  If you are using Off-Net access code on CUCM, you need not to strip it on CUCM and change this dial-peer to 9.T for example.
HTH,
Chris
Community Member
Dear Chris,
Thanks for your support. I try to remove all dial-peer except dial-per voice 1 voip
preference 1
destination-pattern 6002
codec g711ulaw
With only this one, the call ring forever and cant connect to.
how about if you add back dial peer 2? Perhaps that CUCM is not responding or not in the cm group.
Community Member
When i add back dial peer 2, the call can be connected but still after 5 ring times.
I added two call manager in one group already.
Hall of Fame Super Gold
Please take "debug vpm signal" and "debug ccapi inout" with "term mon".
Do not take other debugs. Do not use attachments.
Just poste in the relevant information preferably in a fixed font.
Green
Thanh
Can you clarify if the 5 rings is on calls to or from the PSTN.
I also notice that the CUCM IP addresses and the router IP address are on the same subnet.
They are probably in the same building.
If this is the case you should remove the PLAR OPX to make it just PLAR
voice-port 0/0/0
no connection plar opx 6002
connection plar 6002
Try & test
Alex
Community Member
Dear all,
Please find debug of voicegateway as following:
HO-VG-02#
Feb 20 08:52:47.511: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fx        ols_onhook_ringing
Feb 20 08:52:47.511: htsp_timer - 125 msec
Feb 20 08:52:47.639: htsp_process_event: [0/0/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVE        NT_TIMER]fxols_wait_ring_min_timer
Feb 20 08:52:47.639: htsp_timer - 10000 msec
Feb 20 08:52:48.603: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
Feb 20 08:52:48.603: fxols_ringing_not
Feb 20 08:52:48.603: htsp_timer_stop
Feb 20 08:52:48.603: htsp_timer_stop3 htsp_setup_ind
Feb 20 08:52:48.603: [0/0/0] get_local_station_id calling num=35123497 calling n        ame=PSTN calling time=02/20 08:52  orig called=
Feb 20 08:52:48.603: htsp_process_event: [0/0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SE        TUP_ACK]
Feb 20 08:52:48.603: fxols_wait_setup_ack:
Feb 20 08:52:48.603: htsp_timer - 6000 msec
Feb 20 08:52:48.607: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_PROCEE        DING]fxols_offhook_proc
Feb 20 08:52:52.571: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
Feb 20 08:52:52.571: htsp_timer_stop
Feb 20 08:52:52.571: htsp_timer_stop2
Feb 20 08:52:53.679: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
Feb 20 08:52:53.679: htsp_timer_stop2
Feb 20 08:52:53.679: htsp_timer - 6000 msec
Feb 20 08:52:57.647: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
Feb 20 08:52:57.647: htsp_timer_stop
Feb 20 08:52:57.647: htsp_timer_stop2
Feb 20 08:52:58.759: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
Feb 20 08:52:58.759: htsp_timer_stop2
Feb 20 08:52:58.759: htsp_timer - 6000 msec
Feb 20 08:53:02.703: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
Feb 20 08:53:02.703: htsp_timer_stop
Feb 20 08:53:02.703: htsp_timer_stop2 htsp_alert_notify
Feb 20 08:53:03.647: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alerthtsp_call_service_msghtsp_call_service_msg not EFXS (2)
Feb 20 08:53:03.679: htsp_call_bridged invokedhtsp_call_service_msghtsp_call_service_msg not EFXS (2)
Feb 20 08:53:03.679: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Feb 20 08:53:03.679: [0/0/0] set signal state = 0xC timestamp = 0
Feb 20 08:53:03.679: htsp_timer_stop
Feb 20 08:53:03.679: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Feb 20 08:53:03.883: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0100]fxols_normal_battery
Feb 20 08:53:03.883: htsp_timer_stop2
Feb 20 08:53:03.955: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
Feb 20 08:53:03.955: htsp_timer_stop2
Feb 20 08:53:03.959: htsp_timer_stop2
Feb 20 08:53:20.551: htsp_timer_stop3
Feb 20 08:53:20.567: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
Feb 20 08:53:20.567: htsp_timer_stop
Feb 20 08:53:20.567: htsp_timer_stop2
Feb 20 08:53:20.567: htsp_timer_stop3
Feb 20 08:53:20.567: [0/0/0] set signal state = 0x4 timestamp = 0
Feb 20 08:53:20.567: htsp_timer - 2000 msec
Feb 20 08:53:20.839: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Feb 20 08:53:22.567: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Feb 20 08:53:22.567: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Can you please the trace exactly as indicated above ?
1045
