I have a Vic2-4FXO card installed on a 2811 srst gateway im setting up.
When I dial 9 in fallback mode it doesnt give me a dial tone.
In normal operation it gives me a dial tone after pressing 9, but its not using local router fxo lines.
I've also tried debug vpm command to try to find where the error is occuring, but nothing is displaying on the log.
Any ideas?
Here is the config:
voice-port 0/0/0
timing hookflash-out 500
connection plar opx 7801
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 1 pots
service mgcpapp
port 0/0/0
dial-peer voice 2 pots
service mgcpapp
port 0/0/1
dial-peer voice 3 pots
service mgcpapp
port 0/0/2
dial-peer voice 4 pots
service mgcpapp
port 0/0/3
mgcp
mgcp call-agent 10.1.101.21 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7960 20
limit-dn 7970 2
timeouts ringing 20
ip source-address x.x.x.1 port 2000
max-ephones 42
max-dn 32
access-code fxo 9
voicemail 7700
call-forward busy 7700
call-forward noan 7700 timeout 12
moh HOLD.ulaw.wav
multicast moh x.x.x.1 port 16384 route x.x.x.1 x.x.x.11
also
sh voice port summary
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxo-ls up dorm idle on-hook y
0/0/1 -- fxo-ls up dorm idle on-hook y
0/0/2 -- fxo-ls up dorm idle on-hook y
0/0/3 -- fxo-ls up dorm idle on-hook y
