FXO port not discarding the 8 in 8T and saying no match when dial 8 to PSTN
voice-port 0/0/0
ring number 3
timeouts interdigit 5
timeouts call-disconnect 6
connection plar 1109
voice-port 0/0/1
ring number 3
voice-port 0/0/2
ring number 3
voice-port 0/0/3
ring number 3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 2/0/0
voice-port 2/0/1
connection plar 1100
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
dial-peer voice 269 pots
destination-pattern 8T
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 259 pots
direct-inward-dial
port 0/0/1
dial-peer voice 268 pots
direct-inward-dial
port 0/0/3
dial-peer voice 267 pots
direct-inward-dial
port 0/0/2
Forgot to add this on my previous post;
When I dial 8 follow by my number which is 08011111111 I get engage tone but I debugged it and the output shows something like this,
Calling number; 5521
Called number : 808011111111
And "No match" was written.
Note it has been working before perfectly, it just stopped last week.
Plz what should I do.
What happens if you give forward-digits 11 in the dial-peer.
Also please share debug voip ccapi inout
Senthil
Re: FXO port not discarding the 8 in 8T and saying no match when
this is the output of the debug command i used and i added forward-digit 11. still the same.
Hall of Fame Super Silver
Your dial-peer matching is working fine as the 4 dial peers are matched, can you test one circuit at a time by defining preferences at each dial-peer, ie.
preference 0
keep changing it one by one on each dial-peer to test your circuits one by one to see if there is on stuck in some bad state
Have you tried doing "shut", "no shut" on your voice-ports?
Chris
From the logs i could see that the 4 dial-peers are matched, but the calls fails with the below error cause
DisconnectCause 22  , DisconnectText no circuit (34)
As chris suggested, you can check giving preference and test once circuit at a time,
I also have a small snippet to share, check out whether is this useful.
"The FXO interface configured for GroundStart is polarity sensitive. If       you see a 0x22 disconnect cause code from the output of the debug       debug voip ccapi inout command, you may have the telco ground       connected to the FXO ground on the router. This can be caused by an incorrect       RJ-11 cable between the FXO port and the telco jack. If you are using a       straight through cable try using a crossover, or if you are using a crossover       try using a straight through."
Senthil
456
