FXO port on 2921
I have a VIC2-4FXO that shows up in inventory but not in running config.  Anyone?  I have re-seated and also moved the card.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
FXO port on 2921
Need PVDM3 and UC license to enable the card.
FXO port on 2921
Can you tell us what IOS file the router is configured to use?
FXO port on 2921
15.1
FXO port on 2921
FXO port on 2921
Yeah the client had not installed PVDM before it shipped to the site.  Configuring the DSP's is when i finally noticed the missing PVDM's ...
Thanks to all that replied.  It was the missing PVDM.
FXO port on 2921
Thank you for the nice rating and good luck!
Re: FXO port on 2921
Probably you don't have the UC (Unified Communications) feature activated. You can do show license feature to verify this.
If it is the case, check this link on how the activate a feature on a ISR G2:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
Please rate helpful answer!
FXO port on 2921
Check show version and show diag to check its recognized or not
then try voice-card command
837
