fxo port, outgoing call
pamirian76
hi,
got this config,
voice translation-rule 1000
rule 1 /^9/ //
voice translation-profile STRIP_9
translate called 1000
dial-peer voice 30 pots
translation-profile outgoing STRIP_9
destination-pattern 95554443333
port 0/0/0
forward-digits all
voice-port 0/0/0
connection plar opx "MYHOMEPHONEDID"
description *** HOME DID ***
caller-id enable
when in dial-peer I change destination-pattern to 5554443333 I can call out. when I change it and put the 9 infront it stops working.
ideas?
thanks.
pamirian76
oops my bad got it going.
under telephony-service
I had that number I'm trying to call to test with into after-hours block.
removed that and all is working.
