FXO port ring-trip - users getting constant "half rings"
Just migrated an analog site to IP and pulled the analog lines into a 4 port FXO. The users are reporting half rings every so often with no actual caller on the other end.
What do I need to tweak to kill the ring trips?
voice-port 0/0/0
trunk-group POTS_OUT
timing hookflash-out 50
connection plar opx 1111
description 7409482578
voice-port 0/0/1
connection plar opx 1112
description 7409482562
voice-port 0/0/2
connection plar opx 1010
description 7409482580
voice-port 0/0/3
description 7409482435
Re: FXO port ring-trip - users getting constant "half rings"
Sometimes with these odd problems I find it to be related to battery reversal.
You can try disabling it:
voice-port 0/0/0
no battery
shut
no shut
hth,
nick
trying it now......
No worky.
turns out they are real calls, I just did a real call and it only threw half rings.
Try switching ports/cards/cables, it could be physical.
-nick
I have a location reporting this exact same issue with FXO trunks. I've upgraded code to the latest 12.4(22)T2 and same issue. The secretary finally got to speak to a caller who had called earlier when the half rings where occuring and they stated that the calling party was hearing full rings on their end. I don't really see this as being physical but not sure what it is...possibly a telco issue?
401
