fxo port ringing state
reidg
I have a FXO port connected directly to an exchange line, when I ring this line and look at the "show vOICE PORT SUMMARY" output I get the following:
Operation Status Status
Dorm ring-det on-hook
up idle on-hook
it alternates between these two states when ringing, is this correct???
ta
sebastiandm
Could you provide a sh run of your fxo port....also, where are you pointing this to,fxs/ccm please specify....
voice-port 0/1/0
no echo-cancel enable
cptone GB
timing hookflash-out 50
timing sup-disconnect 50
connection plar 8776
impedance complex2
ccm should be answering and pass to a DN, ignore the PLAR in this setup.
regards
