FXO Port Will Not Dial Out
I have configured 911 dial peers to route out FXO ports on my 1760 router. When I dial 911 the light on the FXO port briefly lights up for half a second then goes out. It then trys the next FXO port and the same thing happens. I then receive a busy signal.
I have verified that the POTS line is good by plugging in an analog phone and dialing out. I have also tried different IOS versions and swapped out the FXO card with new. Nother seems to help. If you have any advice please post. Thanks in advance.
Below is a copy of the debug vpm signal.
000075: htsp_timer_stop3 htsp_setup_req
000076: htsp_process_event: [3/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_se
tup
000077: [3/0] set signal state = 0xC timestamp = 0
000078: htsp_timer - 1300 msec
000079: htsp_process_event: [3/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_pow
er_denial_proc
000080: htsp_timer2 - 1000 msec
000081: htsp_timer_stop
s_timer2_proc
000083: htsp_timer_stop
000084: htsp_timer_stop2
000085: [3/0] set signal state = 0x4 timestamp = 0
000086: htsp_process_event: [3/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_
release
000087: htsp_timer_stop3 htsp_setup_req
000088: htsp_process_event: [3/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_se
tup
000089: [3/1] set signal state = 0xC timestamp = 0
000090: htsp_timer - 1300 msec
000091: htsp_process_event: [3/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
000092: htsp_process_event: [3/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_pow
er_denial_proc
000093: htsp_timer2 - 1000 msec
000094: htsp_timer_stop
000095: htsp_process_event: [3/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxol
s_timer2_proc
000096: htsp_timer_stop
000097: htsp_timer_stop2
000098: [3/1] set signal state = 0x4 timestamp = 0
000099: htsp_process_event: [3/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_
release
000100: htsp_process_event: [3/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
  • IP Telephony
Re: FXO Port Will Not Dial Out
Do you have "forward-digits 3" on your dial peers? Can you post your config?
Brandon
Brandon,
Thanks for replying. This has been becoming a hi-priority issue with the administration. Below is a copy of the 2 dial-peers I use for 911. 8 is our outside access code. I also attached a current copy of the running config on this router.
dial-peer voice 8911 pots
description ***8911 calls over FXO - Priority 1***
destination-pattern 8911
port 3/0
forward-digits 3
dial-peer voice 911 pots
trunkgroup AnalogTrunks
description ***911 calls over FXO - Priority 1***
destination-pattern 911
forward-digits all
Can you dial any other number with the 8T dial peer? Can you dial 8911 which points directly to the 3/0 port?
Brandon
NO...
In SRST mode, I receive a dial tone from the router. When I dial 8 the FXO port briefly lights up then the line goes dead. I cannot make ANY calls out this FXO port.
Under call-manager-fallback, remove the "access-code fxo 8" command.
Brandon
I removed the access-code and placed a test call. The same thing occurs. I have opened a TAC case they want me to upgrade the IOS. I'm not very confident that will fix the problem.
594
