FXO ports don't appear
I installed VWIC-4FXO on 2811 and the ports are not appear with show run and when i check with sh ver the router display the FXO ports
the ios is c2800nm-ipvoice_ivs-mz.124-2.T5.bin
Note that the same card work well with 2801
Thanks for you help
Re: FXO ports don't appear
You likely do not have enough DSP resources for these ports. Do you have other cards installed in the router? Do you have a PVDM installed?
Brandon
That's the pb I have not PVDM installed
Thank u for your help
Is there a PVDM module installed in that router? I had the same problem and after I installed a PVDM8 the ports appear.
114
