Community Member
fxo ports example
hi,
have a 2801 with 1 4 ports fxo card.
let,s say I have 4 1FL lines. 3 of them are cascade and 1 line is a reserved line DID for a store owner.
the first 3 are in a trunk group 1
and I have this,
voice-port 0/0/0
trunk-group 1
connection plar opx 299
caller-id enable
voice-port 0/0/1
trunk-group 1
caller-id enable
voice-port 0/0/3
trunk-group 1
caller-id enable
voice-port 0/0/4
connection plar opx 212
caller-id enable
--> so 299 is my auto attendant and 212 is my own extension.
dial-peer voice 1000 pots
description *** OUTGOING CALLS ***
translation-profile outgoing OUTGOING
trunk-group 1
preference 1
destination-pattern .T
forward-digits all
so any calls going outside I want them to use 1 of the 3 lines.
what I want to do when calling from my 212 extension outside is to tell the cme use port 4. so port 4 is a did reserved for my phone 212. I don't want phone 212 to use one of the trunk-group lines.
how would I do that?
thank you!!
1 REPLY
Community Member
fxo ports example
I just came up with this what do you think?
anything more elegant?
corlist outgoing call-trunk-group
trunk-group 1
preference 1
incoming called-number .
forward-digits all
corlist outgoing CALL-DID-PORT003
port 0/0/3
preference 1
forward-digits all
ephone-dn 14 dual-line
bla bla bla....
corlist incoming CALL-DID-PORT003
ephone-dn 15 dual-line
bla bla bla....
corlist incoming call-trunk-group
even better have a ephone-dn template and assign the template to the ephone-dns.
i have not tested it so not sure if this will even work but it should...
please let me know.
thanks.
114
