FXO ports often hangs
FXO ports are installed in a H.323 GW and often it hangs after the call due to which we are unable to make calls. Everytime we need to login and shut & unshut the ports to release the ports. Any permanent solution to fix this issue...
Thanks & Regards...
Green
This issue appears very often.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml#topic13
Try configuring your FXO port for the correct CPTONE for your country and apply
supervisory disconnect dualtone mid-call
Cant promise that it works.
Alex
Regards, Alex. Please rate useful posts.
I tried with the above command and monitored the ports for couple of days. Still the problem persist. CPTONE is set to SA.
Any other solution?
Thanks & Regards,
Raffi...
Hall of Fame Super Gold
Re: FXO ports often hangs
As Alex correctly hinted, configuring cptone is not enough, you need to configure the exact disconnect tones.
There are many threads on the matter if you search this forum.
224
