Community Member
FXO ports
Hi there,
I have a gateway that is connectec to a PBX using VIC2-4FXO
Frequently those ports keep "bloqued" after being used... and it is necessary to shutdown the ports to make them work again...
This is a example of a port config. Any suggestion for solve this problem ?
voice-port 0/0/3
playout-delay nominal 250
playout-delay minimum high
playout-delay mode fixed
cptone BR
timeouts interdigit 3
Thanks.
Andrei.
Community Member
Re: FXO ports
Here is the summary for FXO disconnect problem:
Problems with FXO
At the end of a VoIP call, both ends hang up the phone or terminate the call. You would expect that all gateway ports involved with the end-to-end call would also disconnect. Sometimes this is not the case with FXO ports when using loop start signaling. There is a common problem known as the FXO disconnect problem.
The FXO port looks like a phone to the central office switch or PBX. The FXO interface closes the loop and the C.O. provides constant battery on the wire. Therefore, there is no disconnect supervision. Just as the switch expects a user to hang up the phone when the call is complete, it also expects the FXO port to hang up. There is no automated process in the router that tells the FXO to disconnect when a call is completed. This is why FXO ports can sometimes become hung up or continue to send ring tones after the call has already cleared. The FXO expects the C.O. switch or PBX to tell it when to hang up. If the local FXO initiated the call and sent it out of its FXO port, then it can supply local disconnect. If it's receiving a call on its FXO then it needs to have a disconnect signal from the PSTN or PBX. Now, there's always a work-around for everything. Here is a list of some of the methods Cisco uses to get around this problem.
Ground-start Signaling Disconnect
Power Denial-based Supervisory Disconnect
Battery Reversal
Tone-based Supervisory Disconnect
Here is solution:
voice-port 0/0/3
timeouts call-disconnect 120 (seconds)
If help pls rate
Community Member
Re: FXO ports
Hi !
Thanks for your help.. now I'm reading this document (FXO Answer and Disconnect Supervision):
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ft_ansds.html
I hope I'm going the right way now.
Thanks.
Andrei.
Community Member
Re: FXO ports
Am I reading this right ?
Is the call comming from one port and going out for another port ?
R_Manaus#sh call activ voice brief
Total call-legs: 2
1821 : 1526 630373900ms.1 +6540 pid:3203 Answer active
dur 00:08:58 tx:0/0 rx:0/0
Tele 0/0/3 (1526) [0/0/3] tx:0/0/0ms None noise:0 acom:0 i/0:0/0 dBm
1821 : 1528 630378320ms.1 +2120 pid:3200 Originate 3276 active
Tele 0/0/0 (1528) [0/0/0] tx:0/0/0ms None noise:0 acom:0 i/0:0/0 dBm
Thanks.
Andrei.
Community Member
Re: FXO ports
I went throught the doc and it did present the tunning options for FXO disconnect supervisor.
Did you ever try one?
For your 'show call active voice brief', it looks two call legs (one incoming to 0/0/3, one outoing from 0/0/0).
As you pointed out you have 4 FXO ports. You may have dial peer to utilitze the call flows to use both FXO ports (0/0/0 & 0/0/3) for some call at same time as in/out.
For disconnect superviosr, can you post output of:
show voice port 0/0/0
Community Member
Re: FXO ports
James, I'm reading the threads and I have a similar disconnect problem on my FXO ports to Avaya IP406 PBX.
I set-up my voice port as below, it almost fix the problem. But there are stil instances that the port remain 'off-hook' even when no calls are active. Any suggestions?
voice-port 0/0/1
supervisory disconnect dualtone mid-call
no battery-reversal
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
impedance complex2
Community Member
Re: FXO ports
Hi, sorry for taking so long...
Here is the voice port output:
Foreign Exchange Office 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is UP
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to fixed
Playout-delay Nominal is set to 250 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to high, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 3 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for BR
Analog Info Follows:
Currently processing Voice
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is Off Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnnct Timing is set to 350 ms
Thanks.
Andrei.
292
