09-06-2007 04:51 AM - edited 03-14-2019 11:24 PM
i have customer connect make voip between 2 pbx the problem is occure in a specefic site where usually when the users in that site make voip call to another site and finish the call the fxo still up and don't close untill i reset it
do u think it a hardware problem or software problem
i attached the configuration so plz read it if u can and till me is it hardware or configuration problem
09-06-2007 05:36 AM
this is the FXO disconnect problem. However, the call showul close after a certain time, which IOS are you using ?
The document that explains the issue is:
http://cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Note: in most countries the only configuration you can use is TONE DISCONNECT DETECTION, other tecniques won't work.
09-06-2007 09:20 AM
Why did you put this upon the voice ports? :
supervisory disconnect dualtone mid-call
supervisory custom-cptone dis
Pure for testing?
