FXO - PSTN
Can both inbound and outbound call works for fxo connecting to pstn, running mgcp gateway?
Appreciate your help. Thanks.
Hiyes , for sure it will work
yes , for sure it will work. Kindly find the below:-
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42101-cm-cfg.html
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42105-vg200-cfg.html
Please rate all useful information
Hi I also recommend for you
I also recommend for you to use H323 , because H323 is better than MGCP especially for FXO , because for example Caller id still has some issues with MGCP.
http://www.cisco.com/c/en/us/support/docs/voice/gateway-protocols/70628-h323-mgcp-compare.html
please rate all useful information
32
