Community Member
FXO Trunking Issues
I have a cme router that is utilizing 7 FXO ports in a trunk. See output below:
Port 0/1/2 is the main incoming number. The problem is that when a call comes in, it will seize that port, and any additional calls will come in and get a RNA. Anyone have any thoughts?
voice-port 0/0/0
trunk-group all 3
input gain 2
output attenuation -1
connection plar 602
description HWIC 0, Port 0,
caller-id enable
voice-port 0/0/1
trunk-group all 2
input gain 2
connection plar 602
description HWIC 0, Port 1,
caller-id enable
voice-port 0/0/2
trunk-group all 1
input gain 2
connection plar 602
description HWIC 0, Port 2,
caller-id enable
voice-port 0/0/3
trunk-group all 7
input gain 2
connection plar 602
description HWIC 0, Port 3,
caller-id enable
voice-port 0/1/0
trunk-group all 6
input gain 2
connection plar 602
description HWIC 1, Port 0,
caller-id enable
voice-port 0/1/1
trunk-group all 5
input gain 2
connection plar 602
description HWIC 1, Port 1,
caller-id enable
voice-port 0/1/2
trunk-group all 64
supervisory disconnect anytone
input gain 2
connection plar 602
description HWIC 1, Port 2,
caller-id enable
1 REPLY
Community Member
Re: FXO Trunking Issues
You cannot control Incoming calls with trunk-group hunting. Trunk-groups only control calls orginating from this gateway. You need to call your provider to have them either setup a hunt-group for you or tell you how it is setup if it exists already.
Then, you should configure the outgoing trunk-group with these priority numbers to be opposite of the incoming calls to avoid glare.
So, if 0/1/2 is the first incoming port it should be the last in line for outgoing calls.
ie "trunk-group all 7" or higher if you chose. The point is that you want to keep it open as much as possible.
150
作成コンテンツを作成するには してください
