Community Member
FXO Trunks or PRI solutions?
FXO Trunks or PRI solutions for small office of 15 or less users?
What ISR and switch to use? CUE for Voicemail? how about faxing?
Everyone's tags (2)
3 ACCEPTED SOLUTIONS
Re: FXO Trunks or PRI solutions?
PRI if thats on the table. Easy to debug
PRI also gives you the flexibility to provision just the needed lines. like you could probably take  a 4 lines on your PRI and just use those channels.
Config wise and debug wise PRI is easier. Personal Troubleshooting experience
2811?
Super Bronze
PRI if the users are busy enough on the phones to warrant the minimum number of channels you are allowed to order (it varies depending on provider).
BRI if you only need a few channels or PRI is too expensive.
FXO if you absolutely can't use anything else - try seaching the forums for FXO voice quality, FXO disconnect supervision, FXO answer supervision to get a sample of some of the problems you are likely to hit. Even if all goes well, FXOs generally have notably lower voice quality.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Quite possibly; it depends on your SP's pricing and your usage.
That's why I suggest BRI (2 channels per circuit) rather then FXO; far more reliable and with much better quality.
Aaron
2811?
Super Bronze
Aaron
Community Member
Thanks much for the input.
Community Member
With just let's say 10 users and with the ratio 1 line per 3 users, PRI will be a waste of money right?
Super Bronze
Aaron
Community Member
for a BRI circuit we're looking at about 6 users or so correct?
Super Bronze
It really depends on the user base; that would seem reasonable but if you have heavy phone users you may need more.
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
1160
