FXO two stage dialing issue
era_cisco
Hi Everyone,
I have strange issue with CISCO2901+VIC2-4FXO installed.
I connected FXO ports using trunk-group to dumb analog Panasonic PBX. Outgoing calls from CISCO to Panasonic is fine, but incoming calls from Panasonic to CISCO FXO ports leads to fast busy.
No PLAR configured, cause I need to catch FXO dial-tone and enter appropriate number using DTMF.
Thx in advance!
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice call disc-pi-off
voice rtp send-recv
voice service voip
 address-hiding
 dtmf-interworking standard
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  header-passing
  error-passthru
  subscription maximum accept 100
  subscription maximum originate 100
  registrar server expires max 28800 min 3600
  early-offer forced
  midcall-signaling passthru
  g729 annexb-all
voice class custom-cptone MEETLEAVE
 dualtone conference
  frequency 400 700
  cadence 150 75 150 50 150 50
voice class custom-cptone MEETME
 dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice register global
 mode cme
 source-address 10.239.87.254 port 5060
 max-dn 20
 max-pool 20
 authenticate presence
 authenticate register
 authenticate realm technopolis.ru
 timezone 32
 time-format 24
 date-format D/M/Y
 call-feature-uri pickup http://10.239.87.254/pickup
 call-feature-uri gpickup http://10.239.87.254/gpickup
 url directory http://10.239.87.254/localdirectory
 tftp-path flash:
 file text
 create profile sync 0001340531943213
 ntp-server 10.239.87.254 mode directedbroadcast
 overlap-signal
voice register dn  1
 number 7001
 name Lomonosov
 no-reg
 label Lomonosov@7001
 mwi
voice register dn  2
 number 7002
 name Mendeleev
 no-reg
 label Mendeleev@7002
 mwi
voice register dn  3
 number 7003
 name Tsiolkovsky
 no-reg
 label Tsiolkovsky@7003
 mwi
voice register pool  1
 registration-timer max 3600 min 240
 id mac 0000.0000.0000
 number 1 dn 1
 dtmf-relay rtp-nte
 username 7001 password 7001
 description Lomonosov
 codec g711ulaw
 no vad
voice register pool  2
 number 1 dn 2
 dtmf-relay rtp-nte sip-kpml cisco-rtp sip-notify
 username 7002 password 7002
 description Mendeleev
 codec g711ulaw
 no vad
voice register pool  3
 number 1 dn 3
 dtmf-relay rtp-nte
 username 7003 password 7003
 description Tsiolkovsky
 codec g711ulaw
 no vad
voice translation-rule 10
 rule 1 /4952568014/ /7001/
 rule 2 /4952568015/ /7002/
 rule 3 /4952568016/ /7003/
 rule 4 /4952568017/ /1107/
voice translation-rule 20
 rule 1 /^8\(.*\)/ /\1/
voice translation-profile SIP-IN1
 translate called 10
voice translation-profile SIP-OUT
 translate called 20
control-plane
voice-port 0/2/0
 trunk-group FXO
 cptone RU
 station-id name CISCO
 station-id number 84952568017
 caller-id enable
 cable-detect
voice-port 0/2/1
 trunk-group FXO
 cptone RU
 caller-id enable
 cable-detect
voice-port 0/2/2
 trunk-group FXO
 cptone RU
 caller-id enable
 cable-detect
voice-port 0/2/3
 trunk-group FXO
 cptone RU
 caller-id enable
 cable-detect
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.239.87.254 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register confdsp1
dspfarm profile 1 conference
 codec g711alaw
 codec g711ulaw
 maximum sessions 12
 conference-join custom-cptone MEETME
 conference-leave custom-cptone MEETLEAVE
 associate application SCCP
dial-peer voice 10 voip
 tone ringback alert-no-PI
 description RELLINE SIP Incoming
 translation-profile incoming SIP-IN1
 preference 8
 destination-pattern 495256801[4567]
 session protocol sipv2
 session target ipv4:195.146.81.135
 session transport udp
 incoming called-number 495256801[4567]
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 100 voip
 description RELLINE SIP City
 preference 8
 destination-pattern 849[59].......
 dtmf-relay rtp-nte
 codec g711ulaw
 clid network-number 4952568017
 no vad
dial-peer voice 101 voip
 description RELLINE SIP Mobile
 preference 8
 destination-pattern 89.........
 dtmf-relay rtp-nte
 codec g711ulaw
 clid network-provided
 no vad
dial-peer voice 102 voip
 description RELLINE SIP National
 preference 8
 destination-pattern 8[02345678].........
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 103 voip
 description RELLINE SIP International
 preference 8
 destination-pattern 810T
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 104 voip
 description RELLINE SIP TIME
 translation-profile outgoing SIP-OUT
 preference 8
 destination-pattern 8100
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 105 voip
 description RELLINE SIP 911
 preference 8
 destination-pattern 80.
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 999 pots
 trunkgroup FXO
 description PANASONIC
 preference 5
 destination-pattern 1...
dial-peer voice 200 pots
 port 0/2/0
dial-peer voice 201 pots
 port 0/2/1
dial-peer voice 202 pots
 port 0/2/2
dial-peer voice 203 pots
 port 0/2/3
 forward-digits 0
presence
 sccp blf-speed-dial retry-interval 70 limit 20
 presence call-list
 max-subscription 200
 watcher all
 allow subscribe
gateway
 timer receive-rtp 1200
sip-ua
 retry invite 3
 timers trying 200
 presence enable
gatekeeper
 shutdown
telephony-service
 sdspfarm conference mute-on 111 mute-off 222
 sdspfarm units 1
 sdspfarm tag 1 confdsp1
 conference hardware
 conference transfer-pattern
 video
  maximum bit-rate 2048
 em keep-history
 xml user axluser password axluser 15
 pin 0000
 fxo hook-flash
 max-ephones 42
 max-dn 200
 ip source-address 10.239.87.254 port 2000
 service phone videoCapability 1
 service phone webAccess 1
 service phone daysDisplayNotActive 1,2,3,4,5,6,7
 service phone displayOnTime 09:00
 service phone displayOnDuration 11:00
 service phone displayIdleTimeout 00.01
 timeouts interdigit 5
 timeouts ringing 600
 timeouts transfer-recall 30
 system message TECHCONGRESS
 cnf-file location flash:
 cnf-file perphone
 time-zone 32
 time-format 24
 date-format dd-mm-yy
 voicemail 1300
 max-conferences 8 gain 0
 call-forward pattern .T
 moh "music-on-hold.au"
 multicast moh 239.10.16.4 port 16384 route 10.239.87.254
 dn-webedit
 transfer-system full-consult
 transfer-pattern .T
 trunk optimization pre-connect
 secondary-dialtone 8
 fac standard
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  octo-line
 number 7077
 label Line1@7077
 mobility
ephone-dn  3  octo-line
 number 7013 no-reg primary
 conference meetme unlocked
 allow watch
 no huntstop
ephone-dn  10  octo-line
 number 7010 no-reg primary
 allow watch
 no huntstop
ephone-dn  11  octo-line
 number 7011 no-reg primary
 allow watch
 no huntstop
ephone-dn  12  octo-line
 number 7012 no-reg primary
 allow watch
 no huntstop
ephone  1
 device-security-mode none
 video
 mac-address 0000.0000.5555
 mtp
 type CIPC
 button  1:1
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 transport input ssh
line vty 5 15
 privilege level 15
 transport input ssh
scheduler allocate 20000 1000
ntp master 3
019413: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=84952568017, Called Number=, Voice-Interface=0x22FC69E8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
019414: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=203
019415: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
019416: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
019417: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
019418: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchSafModulePlugin:
   dialstring=, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
019419: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
019420: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersCore:
019421: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersCore:
019422: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchSafModulePlugin:
019423: Oct  7 22:30:38: //-1/DED95EE3824E/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
019424: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
019425: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
019426: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
019427: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
019428: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
019429: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
019430: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
019431: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
019432: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
019433: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
019434: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
019435: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
019436: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
019437: Oct  7 22:30:38: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
0 Replies 0
