FXO under H323 gateway
Under FXO port used to dial-in and dial-out (old analog line) how can I (when called number and calling number are Unknow) direct this calls to a DN? I've tried voice trans rules and nothing and I can't go to MGCP sinde I have a fract E1 with 15 channels.
PLAR doesn't do the job since I want to use the line for outside also.
Any help?
1 ACCEPTED SOLUTION
Bronze
Re: FXO under H323 gateway
PLAR will do the job. PLAR only applies to calls coming in the FXO port, you can still use dial patterns to send calls out the same port.
Bronze
Tk's
DO not know what I was doing wrong yesterday
Thank you
133
