FXO Unknown number
I have cisco router 2921 with 12 fxo ports (VIC2-4FXO), any call coming form PSTN its displaying (From Unknown number),i try all the cptone and here is the configuration under the voice-port.
voice-port 0/1/0
supervisory disconnect dual tone mid-call
timeouts call -disconnect 5
timeouts wait-release timeout 5
caller-id enable
caller-id alerting ring 2
cptone SA
any other configuration please advice.
Ali Nasser
Re: FXO Unknown number
Ali, Did you subscribe for caller-ID from your service provider?
Hi Allan,
yes, i have caller id in the line and i test it in analog phone i can see the number in 1st ring.
Try to use
caller-id alerting ring 1
Hall of Fame Super Gold
Which exact IOS are you using? the DSP code is often buggy ior flaky in CLID support.
Hi Peolo,
Version 15.0(r1)M6.
That is rommon. Post the full otutput of "show ver".
Hi paolo,
Here is the "show ver"
BR101#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M3, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:32 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
BR101 uptime is 3 days, 21 hours, 23 minutes
System restarted at 15:50:35 UTC Tue Nov 2 2010
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. CISCO2921/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FHK1431F0JG
3 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
2 terminal lines
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
1 cisco Integrated Service Engine(s)
   Cisco Wide Area Application Services Software 4.1.5c (b17 Dec 21 2009 15:41:2
4) in slot 1
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 7.1.7 in slot 0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
If
Cisco
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FHK1431F0JG
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
You are running current software. Engage the Cisco TAC for further support.
Can u provide following debugs for one call ?
deb vpm sig
deb voip ccapi inout
Pl. do following before enabling the debugs...
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 20000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# cler log
Enable above defbugs and place the test call....
Router# term len 0
Router# sh logg
787
