Community Member
FXO using diff codecs
0/0/1         g729r8     n  S_CONNECT             FXOLS_OFFHOOK
0/1/1         g711ulaw   n  S_CONNECT             FXOLS_CONNECT
whats will be the difference between above two since both are connected with different codec.
Everyone's tags (5)
can you add the show run from the gw.
Community Member
trunk group FXO
voice-card 0
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice iec syslog
voice statistics type iec
ip address
h323-gateway voip interface
h323-gateway voip bind srcaddr
voice-port 0/0/1
trunk-group FXO
supervisory disconnect anytone
no battery-reversal
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
cptone SA
timing hookflash-out 50
connection plar 9801
description *** LOCAL LINE ***
music-threshold -45
bearer-cap Speech
caller-id enable
sccp local Loopback10
sccp ccm identifier 2 version 7.0
sccp ccm identifier 1 version 7.0
sccp ccm group 1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register abcd_CONF
associate profile 2 register abcd_XCODE
associate profile 3 register abcd_MTP
dspfarm profile 2 transcode
codec g729r8
codec g711alaw
codec g711ulaw
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 10
dial-peer voice 10 pots
trunkgroup FXO
tone ringback alert-no-PI
destination-pattern 900.T
fax rate disable
prefix 00
dial-peer voice 205 voip
description To CallManager Pub
destination-pattern 9801$
session target ipv4:
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
srst mode auto-provision all
max-ephones 110
max-dn 400
ip source-address port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 May 27 2012 17:41:04
VIP Super Bronze
What exactly do you want to know?
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
I want to know that why some FXO ports are in connected state with G.729r ans some with G.711ualaw. Thanks for your info
Community Member
Hello All
i have the same problem, any idea how to resolve this issue?
