FXO vic problem
Hello there!
I'm testing a cme and everything works fine. FXS works great and i can do all internal calls without any problem. Now i have this issue: i got a external line  with no function besides gives me a dial-tone (when i plug this line into a analogic phone i can hear the dial-tone). I dont know if its a simple pbx line or a sdh line, but the fact is, this dial line doesnt make any call, its just a dial tone line to test the fxo vic. So, what i have to do is press 0 (or any other number) on the ip phones and analogic phones to get a dial tone from the fxo vic like i was making an pstn call. I'm reading for 2 days and made all the changes it would supose to work and nothing works. My phones can't get any dial-tone from the fxo vic. It's a very basic configuration just to test if its everything ok with the equipment and this is my last test and i dont understand why its not working.
Thats what i have:
C2911-CME-SRST/K9 with VIC2-4FXO Four-port Voice Interface Card - FXO (Universal)
WS-C2960-24PC-L
IOS 15.0(1r)M12
CME 8.6
Any ideas how to make it work? I tryed the prefix but didnt help at all. I really dont know if its my configuration problem or if it is this dial-test-line i supose to plug in and test. For my fxo configuration i did:
voice-port 0/1/0
supervisory disconnect dualtone mid-call
cptone BR
timeouts interdigit 2
timeouts call-disconnect 1
timeouts wait-release 1
connection plar 1004
caller-id enable
And aplyed this dial-peer on the voice-port:
dial-peer voice 6 pots
destination-pattern ........
port 0/1/0
forward-digits 8
Thanks and sorry about my english, not my main language... =)
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
FXO vic problem
destination-pattern 9
default forward-digits
then dial 9 to seize line.
FXO vic problem
When you plug a phone in that line that you don't know what it is, can you make calls ?
Because if you don't, there is no point in using it with the router either,
FXO vic problem
No, i can't make any calls from this line, its just a test line. It has signal tho. All i needed to do is press 0 or any other number and get a dial-tone from this test line from analogic and ip phones i have set. I can't make it work.
FXO vic problem
FXO vic problem
Thanks! I will try this as soon as i go to work and i will post the results in here!
FXO vic problem
Thanks a lot Paolo, it worked!
368
