FXO VIC Unrecognised
I have a 2611XM box with a NM-2V running IOS 2600-spservicesk9-mz.124-12.
After installing a VIC-2FXO-EU card in the V0 slot of the NM I was unable to recognise the new VIC. During a reload I get the following errors;
%GUIDO-1-DAUGHTER_CARD_UNKNOWN: NM-HD in slot 1: VIC card
in subslot 1 has an unkown id of 0x16.
%GUIDO-1-DAUGHTER_CARD_FAILED: NM-HD in slot 1: VIC card i
n subslot 1 initialization failed.
Has anyone seen this behaviour before or is it as I suspect a dead VIC card.
1 ACCEPTED SOLUTION
Re: FXO VIC Unrecognised
Are you sure the NM you have is NM-2V or is it NM-HD-2V ? If its NM-HD-2V, it supports only generation 2 vics (VIC2-2FXO) ...
Sankar
PS:L please remember to rate posts!
Sankar
Spot on thanks for the info.
JOF
147
