FXO Voice Delay
I am using a 2811 as an H323 gateway with CCM 4.1(3). On incoming calls to FXO ports, the phones will ring, but there will be a 5 second delay before voice traffic is heard. The person answering the phone may say "hello" but the caller will not hear this. All works fine after the intial few seconds.
Any advice?
R
Re: FXO Voice Delay
We have been having the same problem with a similar setup. Did you ever find a fix for this?
Thanks.
Re: FXO Voice Delay
The problem fixed itself. sorry I could not be of more help.
R
Re: FXO Voice Delay
Robert
I think that is unusual your answer, because the more important in this forum is share the expertices and your answer not helps us.
Cristian Munoz
CCVP
Re: FXO Voice Delay
I am also having this issue at 3 customer sites as well.
I am using 2821 gateways with 7961... H323 protocol to an FXO gateway.
Re: FXO Voice Delay
I think I fixed it.
try this global command
voice rtp send-recv
Please rate post if it fixes your problem.
177
