Fxo voice port status 0/1/0 -fxo-ls up dorm ring-det on-hook y
Hi all ,
Can you give me a idea .. why FXO voice port status are ring-det show...
Green
Try debug vpm signal and look to see if "fxols_rvs_battery" appears in the log.
Then try
voice-port x/x/x
no battery-reversal
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks acampbell , i attach VPM signal debug . please look
Can you please unplug the cable and plug it back,i faced same problem,it resolved after reseting cable in FXO port.
Sreenivasulu thanks for reply  ,,,,, actually i do your propose task but its not work. Can you explaine  me what does it mean Ring-det..
Avijit
1185
