05-14-2012 06:03 PM - edited 03-16-2019 11:09 AM
ext1001 -------fxs (3745 cme 3.3) ip----------ip(2811 cme 8.6)ip--------ext3001
ext1002 ext3002
the topology is as above, dial peer has been setupped,
3001 can call 3002,1001, 1002
1001 can only call 1002
1001 call 3001 or 3002 get a busy tone after a few seconds,
I tried debug dial peer on both router, it seem all successfull. but the ip phone just doesn't ring.
I have been trying fix it for a few days and get no clue at all. Will that something related to cme version or codec?
PLEASE HELP ME~~~~
3745 config
voice-port 1/0/0
ring cadence pattern08
cptone AU
timeouts initial 5
timeouts interdigit 5
timeouts call-disconnect 2
timeouts ringing 60
description RED PHONE
station-id name D
voice-port 1/0/1
cptone AU
timeouts initial 5
timeouts ringing 60
description GREY PHONE
station-id name P
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 1001 pots
destination-pattern 1001
port 1/0/0
dial-peer voice 1002 pots
destination-pattern 1002
port 1/0/1
dial-peer voice 3000 voip
destination-pattern 30..
session target ipv4:3.3.3.3
dial-peer voice 3001 voip
destination-pattern 3001
telephony-service
max-conferences 8 gain -6
2811 config
ccm-manager music-on-hold bind Loopback0
mgcp profile default
dial-peer voice 1000 voip
destination-pattern 10..
session target ipv4:1.1.1.1
gatekeeper
shutdown
telephony-service
moh-file-buffer 2000
internal-call moh-group 0
max-ephones 6
max-dn 12
ip source-address 3.3.3.3 port 2000
load 7960-7940 P00308010200
load 7941 term41.default
load 7941GE term41.default
moh music-on-hold.au
multicast moh 239.1.1.10 port 16384
transfer-system full-consult
login timeout 10
after-hours day Tue 22:00 06:00
after-hours date Dec 25 00:00 23:59
after-hours date Mar 1 00:00 23:59
directory last-name-first
directory entry 3 3001 name Dongbo Li
create cnf-files version-stamp 7960 Mar 01 2002 03:18:29
ephone-dn 1 dual-line
number 3001
pickup-group 3001
name Dongbo Li
ephone-dn 2 dual-line
number 3002
pickup-group 3001
name Evan Li
ephone-dn 3 octo-line
number 3003
pickup-group 3004
name Patrick Huang
ephone-dn 4
number 3010
park-slot timeout 10 limit 2
ephone-dn 5
number A100
intercom A101 label "Manager"
ephone-dn 6
number A101
intercom A100 no-mute label "Secretary" ptt
ephone-dn 7 dual-line
number 3004
name ip communicator
ephone 1
device-security-mode none
mac-address 0023.5E1A.6445
paging-dn 7
type 7941
button 1:1 2:5
ephone 2
mac-address 0009.B7F9.C9EC
after-hours exempt
paging-dn 7
type 7960
button 1:2 2:6
pin 1234
ephone 3
mac-address 0013.1978.36A9
button 1:3
ephone 4
mac-address 000C.29EA.E3C7
type CIPC
button 1:7
Solved! Go to Solution.
05-15-2012 12:23 AM
On your 2811 router configure the following
voice service voip
ip address trusted list
ipv4 X.x.x.x 255.255.255.255
where x.x.x.x is your 3745 router ip address and try again
05-14-2012 07:00 PM
please provide configs
05-14-2012 07:11 PM
will do as soon as i get home
05-14-2012 11:04 PM
configuration posted,
Any idea why?
05-15-2012 12:11 AM
can you do a test call and send the ff:
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
05-15-2012 12:17 AM
Mar 1 02:38:57.675: //56/2CE51F1D804D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x64A4519C, Tag=0x0, Call Id=56,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Mar 1 02:38:58.491: //-1/50FF11388050/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0
Mar 1 02:38:58.495: //-1/50FF11388050/CCAPI/cc_api_call_setup_ind_common:
Interface=0x64A4519C, Call Info(
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=1002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 1 02:38:58.495: //-1/50FF11388050/CCAPI/ccCheckClipClir:
In: Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/cc_process_call_setup_ind:
Event=0x649FF350
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallSetContext:
Context=0x63D5DBA4
>>>>CCAPI handed cid 58 with tag 1002 to app "_ManagedAppProcess_Default"
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallSetupAck:
Call Id=58
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=58
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 1 02:38:58.495: //58/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x3A, digit_event=0x1, enable=TRUE, consume=FALSE)
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=58
Mar 1 02:38:58.495: //58/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x64A4519C, callID=0x3A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Mar 1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_call_report_digits_done:
HQ#Enabled=TRUE, Disposition=0x0, Interface=0x64A4519C, Call Id=58
Call Entry(Initial Digit Timeout=5000(ms), Inter Digit Timeout=5000(ms))
Mar 1 02:38:59.455: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
Source Call Id=58, Digit=3, DigitBeginFlags=0x1,
Rtp Timestamp=0xFFFFFE70, Rtp Expiration=0x0
Mar 1 02:38:59.547: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
Source Call Id=58, Digit=3, Duration=125,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Mar 1 02:39:00.015: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
Source Call Id=58, Digit=0, DigitBeginFlags=0x1,
Mar 1 02:39:00.075: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
HQ#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
Source Call Id=58, Digit=0, Duration=95,
Mar 1 02:39:00.195: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
Mar 1 02:39:00.295: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
Source Call Id=58, Digit=0, Duration=135,
Mar 1 02:39:00.895: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
Source Call Id=58, Digit=2, DigitBeginFlags=0x1,
Mar 1 02:39:00.975: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
Source Call Id=58, Digit=2, Duration=115,
Mar 1 02:39:00.975: //58/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x3A, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 1 02:39:00.975: //58/50FF11388050/CCAPI/ccCallReportDigits:
Mar 1 02:39:00.975: //58/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x64A4519C, callID=0x3A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 1 02:39:00.975: //58/50FF11388050/CCAPI/cc_api_call_report_digits_done:
Mar 1 02:39:00.975: //58/50FF11388050/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Mar 1 02:39:00.979: //58/50FF11388050/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3000, Params=0x63D515F4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 1 02:39:00.979: //58/50FF11388050/CCAPI/ccCheckClipClir:
Destination Pattern=30.., Called Number=3002, Digit Strip=FALSE
Called Number=3002(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Patrick
Account Number=, Final Destination Flag=FALSE,
Guid=50FF1138-2BF4-11D6-8050-CBD4EC99B4E1, Outgoing Dial-peer=3000
Mar 1 02:39:00.979: //58/50FF11388050/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=3002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Mar 1 02:39:00.979: //58/50FF11388050/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x64800D84, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=3002(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 1 02:39:00.979: //59/50FF11388050/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Mar 1 02:39:00.979: //59/50FF11388050/CCAPI/ccCallSetContext:
Context=0x63D515A4
Mar 1 02:39:00.979: //58/50FF11388050/CCAPI/ccSaveDialpeerTag:
Mar 1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_call_disconnected:
Cause Value=21, Interface=0x64800D84, Call Id=59
Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
Mar 1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Mar 1 02:39:00.999: //59/50FF11388050/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=59
Mar 1 02:39:00.999: //59/50FF11388050/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Mar 1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x64800D84, Tag=0x0, Call Id=59,
Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
HQ#
Mar 1 02:39:00.999: //58/50FF11388050/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 1 02:39:00.999: //58/50FF11388050/CCAPI/cc_api_get_transfer_info:
Mar 1 02:39:00.999: //58/50FF11388050/CCAPI/cc_api_call_disc_cause_update:
Cause Value=16
Call Entry(Disconnect Cause=16)
Mar 1 02:40:51.179: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
forwardLogicalChannelNumber 1
forwardLogicalChannelParameters
dataType audioData : g729 : 2
multiplexParameters h2250LogicalChannelParameters :
sessionID 1
mediaControlChannel unicastAddress : iPAddress :
network '9C851A01'H
tsapIdentifier 19265
silenceSuppression TRUE
Mar 1 02:40:51.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000D4001800B050001009C851A014B4180
Mar 1 02:40:51.179:
dataType nullData : NULL
multiplexParameters none : NULL
reverseLogicalChannelParameters
sessionID 1
mediaChannel unicastAddress : iPAddress :
network '9C851A01'H
tsapIdentifier 19264
network '9C851A01'H
Mar 1 02:40:51.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004D40018012150001009C851A014B40009C851A014B4180
Mar 1 02:40:51.179:
Mar 1 02:40:51.183: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
version 18
protoParam qsigNonStdInfo :
iei 28
rawMesg '1C399E0100036774640000002E49414D2C0D0A47...'H
progIndParam progIndIEinfo :
progIndIE '00000003'H
Mar 1 02:40:51.183: H225 NONSTD OUTGOING ENCODE BUFFER::= E0011200011C3B1C399E0100036774640000002E49414D2C0D0A4743492C39323637373366353262663431316436383035336362643465633939623465310D0A0D0A088006000400000003
Mar 1 02:40:51.183:
Mar 1 02:40:51.183: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
protocolIdentifier { 0 0 8 2250 0 4 }
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID '926773F52BF411D68053CBD4EC99B4E1'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip '9C851A01'H
port 56934
callIdentifier
guid '926773F52BF411D68055CBD4EC99B4E1'H
fastStart
'0000000D4001800B050001009C851A014B4180'H,
'400000060401004D40018012150001009C851A01...'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls TRUE
maintainConnection TRUE
symmetricOperationRequired NULL
h245Tunneling TRUE
nonStandardControl
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data 'E0011200011C3B1C399E0100036774640000002E...'H
tunnelledSignallingMessage
tunnelledProtocolID
id tunnelledProtocolAlternateID :
protocolType "gtd"
messageContent
'49414D2C0D0A4743492C39323637373366353262...'H
Mar 1 02:40:51.187: H225.0 OUTGOING ENCODE BUFFER::= 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
Mar 1 02:40:51.187:
Mar 1 02:40:51.203: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A000411001100926773F52BF411D68055CBD4EC99B4E110800180
Mar 1 02:40:51.203:
Mar 1 02:40:51.203: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling TRUE
Mar 1 02:40:51.203: H225.0 OUTGOING PDU ::=
HQ#
h323-uu-pdu
callIdentifier
h245Tunneling TRUE
Mar 1 02:40:51.203: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100926773F52BF411D68055CBD4EC99B4E110800180
Mar 1 02:40:51.203:
05-15-2012 12:23 AM
voice service voip
05-15-2012 12:26 AM
Champion! Thanks a lot.
