fxs analog phone can not call IP phone
ext1001 -------fxs (3745 cme 3.3) ip----------ip(2811 cme 8.6)ip--------ext3001
ext1002        ext3002
the topology is as above, dial peer has been setupped,
3001 can call 3002,1001, 1002
1001 can only call 1002
1001 call 3001 or 3002 get a busy tone after a few seconds,
I tried debug dial peer on both router, it seem all successfull. but the ip phone just doesn't ring.
I have been trying fix it for a few days and get no clue at all. Will that something related to cme version or codec?
PLEASE HELP ME~~~~
3745 config
voice-port 1/0/0
ring cadence pattern08
cptone AU
timeouts initial 5
timeouts interdigit 5
timeouts call-disconnect 2
timeouts ringing 60
description RED PHONE
station-id name D
voice-port 1/0/1
cptone AU
timeouts initial 5
timeouts ringing 60
description GREY PHONE
station-id name P
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 1001 pots
destination-pattern 1001
port 1/0/0
dial-peer voice 1002 pots
destination-pattern 1002
port 1/0/1
dial-peer voice 3000 voip
destination-pattern 30..
session target ipv4:3.3.3.3
dial-peer voice 3001 voip
destination-pattern 3001
telephony-service
max-conferences 8 gain -6
2811 config
ccm-manager music-on-hold bind Loopback0
mgcp profile default
dial-peer voice 1000 voip
destination-pattern 10..
session target ipv4:1.1.1.1
gatekeeper
shutdown
telephony-service
moh-file-buffer 2000
internal-call moh-group 0
max-ephones 6
max-dn 12
ip source-address 3.3.3.3 port 2000
load 7960-7940 P00308010200
load 7941 term41.default
load 7941GE term41.default
moh music-on-hold.au
multicast moh 239.1.1.10 port 16384
transfer-system full-consult
login timeout 10
after-hours day Tue 22:00 06:00
after-hours date Dec 25 00:00 23:59
after-hours date Mar 1 00:00 23:59
directory last-name-first
directory entry 3 3001 name Dongbo Li
create cnf-files version-stamp 7960 Mar 01 2002 03:18:29
ephone-dn  1  dual-line
number 3001
pickup-group 3001
name Dongbo Li
ephone-dn  2  dual-line
number 3002
pickup-group 3001
name Evan Li
ephone-dn  3  octo-line
number 3003
pickup-group 3004
name Patrick Huang
ephone-dn  4
number 3010
park-slot timeout 10 limit 2
ephone-dn  5
number A100
intercom A101 label "Manager"
ephone-dn  6
number A101
intercom A100 no-mute label "Secretary" ptt
ephone-dn  7  dual-line
number 3004
name ip communicator
ephone  1
device-security-mode none
mac-address 0023.5E1A.6445
paging-dn 7
type 7941
button  1:1 2:5
ephone  2
mac-address 0009.B7F9.C9EC
after-hours exempt
paging-dn 7
type 7960
button  1:2 2:6
pin 1234
ephone  3
mac-address 0013.1978.36A9
button  1:3
ephone  4
mac-address 000C.29EA.E3C7
type CIPC
button  1:7
1 ACCEPTED SOLUTION
VIP Super Bronze
On your 2811 router configure the following
voice service voip
ip address trusted list
  ipv4 X.x.x.x 255.255.255.255
where x.x.x.x is your 3745 router ip address and try again
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
please provide configs
Please remember to rate useful posts, by clicking on the stars below.
will do as soon as i get home
configuration posted,
Any idea why?
VIP Super Bronze
can you do a test call and send the ff:
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
  • debug voip ccapi inout
Mar  1 02:38:57.675: //56/2CE51F1D804D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64A4519C, Tag=0x0, Call Id=56,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar  1 02:38:58.491: //-1/50FF11388050/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0
Mar  1 02:38:58.495: //-1/50FF11388050/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x64A4519C, Call Info(
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=1002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar  1 02:38:58.495: //-1/50FF11388050/CCAPI/ccCheckClipClir:
   In: Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/cc_process_call_setup_ind:
   Event=0x649FF350
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallSetContext:
   Context=0x63D5DBA4
   >>>>CCAPI handed cid 58 with tag 1002 to app "_ManagedAppProcess_Default"
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallSetupAck:
   Call Id=58
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=58
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar  1 02:38:58.495: //58/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3A, digit_event=0x1, enable=TRUE, consume=FALSE)
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=58
Mar  1 02:38:58.495: //58/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x64A4519C, callID=0x3A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Mar  1 02:38:58.495: //58/50FF11388050/CCAPI/cc_api_call_report_digits_done:
HQ#Enabled=TRUE, Disposition=0x0, Interface=0x64A4519C, Call Id=58
   Call Entry(Initial Digit Timeout=5000(ms), Inter Digit Timeout=5000(ms))
Mar  1 02:38:59.455: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=58, Digit=3, DigitBeginFlags=0x1,
   Rtp Timestamp=0xFFFFFE70, Rtp Expiration=0x0
Mar  1 02:38:59.547: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
   Source Call Id=58, Digit=3, Duration=125,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Mar  1 02:39:00.015: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
   Source Call Id=58, Digit=0, DigitBeginFlags=0x1,
Mar  1 02:39:00.075: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
HQ#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=58, Digit=0, Duration=95,
Mar  1 02:39:00.195: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
Mar  1 02:39:00.295: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
   Source Call Id=58, Digit=0, Duration=135,
Mar  1 02:39:00.895: //58/50FF11388050/CCAPI/cc_api_call_digit_begin:
   Source Call Id=58, Digit=2, DigitBeginFlags=0x1,
Mar  1 02:39:00.975: //58/50FF11388050/CCAPI/cc_api_call_digit_end:
   Source Call Id=58, Digit=2, Duration=115,
Mar  1 02:39:00.975: //58/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x3A, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar  1 02:39:00.975: //58/50FF11388050/CCAPI/ccCallReportDigits:
Mar  1 02:39:00.975: //58/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x64A4519C, callID=0x3A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar  1 02:39:00.975: //58/50FF11388050/CCAPI/cc_api_call_report_digits_done:
Mar  1 02:39:00.975: //58/50FF11388050/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar  1 02:39:00.979: //58/50FF11388050/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3000, Params=0x63D515F4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar  1 02:39:00.979: //58/50FF11388050/CCAPI/ccCheckClipClir:
   Destination Pattern=30.., Called Number=3002, Digit Strip=FALSE
   Called Number=3002(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Patrick
   Account Number=, Final Destination Flag=FALSE,
   Guid=50FF1138-2BF4-11D6-8050-CBD4EC99B4E1, Outgoing Dial-peer=3000
Mar  1 02:39:00.979: //58/50FF11388050/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=1002
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3002
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Mar  1 02:39:00.979: //58/50FF11388050/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x64800D84, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=1002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3002(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3000, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar  1 02:39:00.979: //59/50FF11388050/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Mar  1 02:39:00.979: //59/50FF11388050/CCAPI/ccCallSetContext:
   Context=0x63D515A4
Mar  1 02:39:00.979: //58/50FF11388050/CCAPI/ccSaveDialpeerTag:
Mar  1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x64800D84, Call Id=59
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
Mar  1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Mar  1 02:39:00.999: //59/50FF11388050/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=59
Mar  1 02:39:00.999: //59/50FF11388050/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Mar  1 02:39:00.999: //59/50FF11388050/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64800D84, Tag=0x0, Call Id=59,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
HQ#
Mar  1 02:39:00.999: //58/50FF11388050/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar  1 02:39:00.999: //58/50FF11388050/CCAPI/cc_api_get_transfer_info:
Mar  1 02:39:00.999: //58/50FF11388050/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
   Call Entry(Disconnect Cause=16)
  • debug h225 asn1
  • debug h245 asn1
Mar  1 02:40:51.179: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g729 : 2
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '9C851A01'H
            tsapIdentifier 19265
          silenceSuppression TRUE
Mar  1 02:40:51.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000D4001800B050001009C851A014B4180
Mar  1 02:40:51.179:
        dataType nullData : NULL
        multiplexParameters none : NULL
      reverseLogicalChannelParameters
          sessionID 1
          mediaChannel unicastAddress : iPAddress :
            network '9C851A01'H
            tsapIdentifier 19264
            network '9C851A01'H
Mar  1 02:40:51.179: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004D40018012150001009C851A014B40009C851A014B4180
Mar  1 02:40:51.179:
Mar  1 02:40:51.183: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
      version 18
      protoParam qsigNonStdInfo :
        iei 28
        rawMesg '1C399E0100036774640000002E49414D2C0D0A47...'H
      progIndParam progIndIEinfo :
        progIndIE '00000003'H
Mar  1 02:40:51.183: H225 NONSTD OUTGOING ENCODE BUFFER::= E0011200011C3B1C399E0100036774640000002E49414D2C0D0A4743492C39323637373366353262663431316436383035336362643465633939623465310D0A0D0A088006000400000003
Mar  1 02:40:51.183:
Mar  1 02:40:51.183: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 4 }
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '926773F52BF411D68053CBD4EC99B4E1'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '9C851A01'H
            port 56934
          callIdentifier
            guid '926773F52BF411D68055CBD4EC99B4E1'H
          fastStart
            '0000000D4001800B050001009C851A014B4180'H,
            '400000060401004D40018012150001009C851A01...'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls TRUE
          maintainConnection TRUE
          symmetricOperationRequired NULL
        h245Tunneling TRUE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'E0011200011C3B1C399E0100036774640000002E...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '49414D2C0D0A4743492C39323637373366353262...'H
Mar  1 02:40:51.187: H225.0 OUTGOING ENCODE BUFFER::= 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
Mar  1 02:40:51.187:
Mar  1 02:40:51.203: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A000411001100926773F52BF411D68055CBD4EC99B4E110800180
Mar  1 02:40:51.203:
Mar  1 02:40:51.203: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling TRUE
Mar  1 02:40:51.203: H225.0 OUTGOING PDU ::=
HQ#
      h323-uu-pdu
          callIdentifier
        h245Tunneling TRUE
Mar  1 02:40:51.203: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100926773F52BF411D68055CBD4EC99B4E110800180
Mar  1 02:40:51.203:
VIP Super Bronze
voice service voip
Champion! Thanks a lot.
522
