FXS and Faxes
Hi all,
I cant for the life of me get my fax solution to work I brought a VIC2-2FSX and want to have two fax machines off of it. Does anyone have a config already configured I can look at. I seem to get one thing sorted then another thing breaks. Exsample inbound calls go to the right port but only one will ring. or I plug a phone into port 0 and I pick up the phone and port 1 goes off hook
Paul
Re: FXS and Faxes
HI,
IS you gateway is MGCP or H323 configured ?
I have some conf example for you.
Luc
Re: FXS and Faxes
Hi Luc,
The next hop is a sip hop, but the gateway is h323. It seems to be more a phisical voice port conf issue as the calls are doing strange things.
Paul
Hall of Fame Super Gold
Re: FXS and Faxes
please check that your phone/fax cable use two and only two central wires in the rj-11 connector. Port 1 is also cabled in port 0 as ping 2-5 and some phones can cuase that using multiwire cable.
Hope this helps, please ratepost if it does!
Re: FXS and Faxes
Yep thats seems to be the issue , butchered the cable and it works fine. It wont ring my phone but the fax works fine.
Many thanks
Paul
150
