FXS Card
If I add an FXS card into a 3845 voice router, are there any DSP consideration?
Re: FXS Card
Sure. The router will allocate a certain amount of DSP resources for each analog interface on the FXS card. This allocation occurs on boot up.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Re: FXS Card
Thank you for the Reply - Can you tell me how I can tell if I have enough DSP resources for this card?
Re: FXS Card
You can see the number of PVDMs installed (carrier cards for DSP modules) by executing this command:
show diag | i PVDM
You can see the allocation of DSP resources using this command:
show voice dsp group all
HTH.
Bill
Please remember to rate helpful posts.
428
