FXS Dial Tone
I have an H323 gateway with a VIC3-2FXS/DID, and cannot get dialtone out of the fxs ports.
I have not configured direct-inward-dial on the pots dial-peer, and the fxs port is set for loopstart. I have shut/no shut the voiceport and the dial-peer.
I think that I'm missing something simple, but can't come up with it.
dial-peer voice 1000 pots
destination-pattern 1000
fax rate disable
port 0/1/0
voice-port 0/1/0
station-id number ******1000
caller-id enable
Foreign Exchange Station 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
Type of VoicePort is FXS VIC3-2FXS/DID
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number ******1000
Caller ID Info Follows:
Standard BELLCORE
Output attenuation is set to 14 dB
Caller ID is transmitted after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Jeff
1 ACCEPTED SOLUTION
Re: FXS Dial Tone
This is actually a quirk in the way dial peers are matched.
What's happening is your dial peer is matching a direct-inward-dial peer because the station-id on the voice port is matching against your destination-pattern on your PRI dial peer.
The easiest way to prevent this is to:
-Change the destination pattern on that dial peer so the station-id doesn't match it any longer
-Add 'answer-address' on the dial peer you want it to match that will match the station-id
-Remove station-id from the port
hth,
nick
Hall of Fame Super Gold
Re: FXS Dial Tone
Maybe IOS bug, what are you running ?
Re: FXS Dial Tone
12.4.20T2
I'm trying to schedule a power cycle, but I'm not sure what else to do short of calling TAC.
Re: FXS Dial Tone
I suggest doing a 'debug voip ccapi inout' and doing a search for peer= or just doing a 'debug voip dial-peer' to see which incoming dial peer you're hitting.
If it has service mgcpapp or service stcapp on it and it's not correctly registered it will give you this problem.
You can also do 'debug vpm signal' and make sure 'term mon' is on. Try doing a 'conf t' and 'exi' to make sure you get the 'configure by console/vty' message that debugs are working. Then go off/on hook and see if you're getting debugs. If you don't get any debugs you've probably got a bad port on the card. Try the other port. If you do get debugs it means it's an application problem, and you probably need to register the port with SCCP/MGCP.
-nick
Re: FXS Dial Tone
I have actually tried this both with mgcp and h323. Neither is giving dial tone.
I opened a tac case, and they ended up rma'ing the card. The new vwic is still not providing dial tone.
I'm scratching my head.
I still need to grab a debug voip ccapi inout.
Re: FXS Dial Tone
I've attached a debug voip ccapi inout, debug voice dialpeer all, and debug vpm signal.
It looks like the dialpeer voice 1 pots is being matched when the phone goes off hook, which has the direct-inward-dial. I didn't know that a dial-peer was instantly matched?
dial-peer voice 1 pots
translation-profile outgoing Outbound
destination-pattern .T
fax rate disable
direct-inward-dial
port 0/0/0:23
fax rate disable
port 0/1/0
Thanks.
Re: FXS Dial Tone
hth,
nick
Re: FXS Dial Tone
Nick,
Thanks. I figured this out after the debug dialpeer, and put a stricter match on the outbound pots dialpeer to prevent it from being matched.
That explanation is a huge help though. I didn't understand why it was really matching.
686
