Bronze
FXS/DID number of digits outpulsed different than what is recieved
I have analog DID's from the Telco configured for wink-start.  A switch tech has confirmed they are outpulsing 4 digits.  However, "debug vpm all" shows only 3 digits recieved and when configured for 3 works fine.  Could there be a potential timing issue where the router is not ready to recieve the leading digit? If so what are some suggested timing commands?
Testing late last night and had to plug them back into production dialogic board so I don't have a working "debug vpm all" output right now.
3845
12.4.24(T4)
vic3-4fxs/did
voice-port 0/3/0
signal did wink-start
dial-peer voice 500 voip
description "To Call Manager"
destination-pattern [0-9]...
voice-class codec 1
voice-class h323 1
session target ipv4:x.x.x.x
incoming called-number .
dtmf-relay h245-alphanumeric
Thanks in advance.
Re: FXS/DID number of digits outpulsed different than what is re
I am assuming its the leading digit (first digit) that is missing ?
Most likely due to the cause you have identified aleady. Router
port not ready before the digit comes in...so yes, a timing issue.
GW should be ready soon after it sends wink to rec. the digits
and doubt we can change any port timing on IOS side for it to
rec. digits faster.
Switch side needs to introduce a little delay (few hundred millisec)
after rec. the wink before outpusling the digits for it to work properly.
Or is it that they are outpulsing without waiting for a wink ? In which
case, you shd be configured for immediate-start - have u tried that
just for testing sake?
Can u share ur config along with vpm signal digits ?
Bronze
Applicable configuration below.  The analog DID's can only be tested after hours so I will have to try the signal immediate again later on.  Unfortunately I did not save any of the debug vpm outputs so I will have to get that later. Voice Port 0/3/0 - 3 are my ports in question.
voice call carrier capacity active
voice service voip
fax protocol cisco
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
  h225 timeout tcp establish 30
controller T1 0/0/0
shutdown
controller T1 0/0/1
shutdown
controller T1 0/1/0
pri-group timeslots 1-24 service mgcp
controller T1 0/1/1
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
ip flow ingress
duplex auto
speed auto
media-type rj45
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/1/0:23
echo-cancel coverage 64
voice-port 0/1/1:23
voice-port 0/2/0
echo-cancel coverage 24
timing hookflash-out 50
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 9600
mgcp fax t38 ls_redundancy 2
mgcp fax t38 hs_redundancy 2
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
preference 1
voice-class codec 1
voice-class h323 1
dial-peer voice 501 voip
description "To call Manager"
voice-class codec 1
voice-class h323 1
dial-peer voice 100 pots
direct-inward-dial
port 0/3/0
dial-peer voice 101 pots
direct-inward-dial
port 0/3/1
dial-peer voice 102 pots
direct-inward-dial
port 0/3/2
dial-peer voice 103 pots
direct-inward-dial
port 0/3/3
We just experienced this exact issue. Using a buttset we could monitor the DTMF tones. The digits were being sentfrom the CO switch before the cisco gateway wink was complete. We also would miss the first inbound digit. We solved this by changing the wink duration to be shorter. This is in the Timing config.
1039
