FXS/DID once enabled, goes straight to seized
We moved a DID trunk from a PBX to a FXS/DID card. Supposedly the telco is using wink-start. As soon as we enable the port and plug the cable in, the port goes seized on the inbound status of the port. I've tried each signaling type just in case and all come back with the same result.
I thought maybe it could be a port on the provider side that they could bounce or was busied out once we unplugged it, but they said that line type can't be bounced or busied out.
Any thoughts on this?
As soon as I enable the port, we get this:
Aug 14 05:44:44.108: htsp_process_event: [0/3/0, S_DOWN, E_HTSP_IF_INSERVICE]
Aug 14 05:44:44.108: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/3/0, changed state to up
Aug 14 05:44:44.108: Foreign Exchange Station 0/3/0 rx_signal_map:
0 C C C
4 C 6 C
C C C C
C C C C
Aug 14 05:44:44.108: [0/3/0] set signal state = 0x4 timestamp = 0
Aug 14 05:44:44.108: Foreign Exchange Station 0/3/0 tx_signal_map:
4 4 4 4
4 4 4 4
C C C C
C C C C
Aug 14 05:44:44.108: htsp_process_event: [0/3/0, S_OPEN_PEND, E_HTSP_GO_UP] htsp_fxs_did_create
Aug 14 05:44:44.460: htsp_process_event: [0/3/0, DID_NULL, E_HTSP_INIT]fxs_did_null_init  did_onhook
Aug 14 05:44:44.460: [0/3/0] set signal state = 0x4 timestamp = 0
Aug 14 05:44:44.460: htsp_process_event: [0/3/0, DID_INIT, E_HTSP_INSERVE]fxs_did_init_inserve
Aug 14 05:44:44.460: did_stop_timer
Aug 14 05:44:44.460: htsp_timer_stop  did_onhook
Aug 14 05:44:44.460: did_start_timer: 10000 ms
Aug 14 05:44:44.460: htsp_timer - 10000 msec
Aug 14 05:44:44.460: htsp_process_event: [0/3/0, DID_PENDING, E_DSP_SIG_1100]did_park_offhook
Aug 14 05:44:44.460: htsp_process_event: [0/3/0, DID_PARK, E_DSP_SIG_1100]did_park_offhook
The config is fairly simple on the voice-port:
voice-port 0/3/0
signal did wink-start
show voice port summary shows this:
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      up    dorm idle     on-hook  y
0/3/0           --  did-in-wnk  up    up   seized   idle     y
0/3/1           --  fxs-ls      up    dorm on-hook  idle     y
Green
Bryan,
DID trunks are polarity sensitive.
Try reversing the cable pair
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Need to ask if there a
Need to ask if there a resolution to this post?
We too have encountered same issue using a VIC3-4FXS/DID with four DID trunks.
I'm very confused with this situation.
Thanks in advance.
374
