Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
FXS / FAX issue with 2821 router
I am having an issue setting up a fax machine connected to a VIC2-2FXS card. The issue is that when I dial in with the fax machine connected, it goes directly to a dial tone. If I dial 9 and a number I can place a call. (not the desired result) If I connect up a analog phone, it rings and I can answer and talk just fine.
For configuration, I am using IOS 12.4(19b) [I have tried various IOS version]
My clock settings are network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
Yes, this is a E1 line located in UK.
The port is:
voice-port 0/3/0
And the dial peer is:
dial-peer voice 120 pots
description Fax Machine
destination-pattern 980871
port 0/3/0
I am getting 6 digits from the provider so I am matching on all digits.
I am doing this in 3 other offices in US and it works fine, so I am stumped to what is wrong.
Attached it a debug of the q931 and dialpeer.
Re: FXS / FAX issue with 2821 router
I think you need a station-id command under the voice-port... Also is this a 3G fax?
HTH, please rate useful posts
Chad
Do you have direct-inward-dial configured on the inbound POTS dial-peer
Dave
Here is all my dial-peers.
dial-peer voice 201 voip
description call routing for incoming calls (subscriber)
preference 1
destination-pattern 98....
session target ipv4:172.30.9.2
dtmf-relay h245-alphanumeric
dial-peer voice 202 voip
description call routing for incoming calls (publisher)
preference 2
session target ipv4:172.30.9.1
dial-peer voice 100 pots
description Call Routing for Emergency
destination-pattern 9999
progress_ind setup enable 3
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
forward-digits 3
dial-peer voice 103 pots
description call routing for international calls
translation-profile outgoing outgoing
destination-pattern 900.T
direct-inward-dial
port 0/0/0:15
prefix 00
dial-peer voice 104 pots
description Call routing for UK Mobile
destination-pattern 907[1-9]........
port 0/0/0:15
forward-digits 11
dial-peer voice 105 pots
description Call routing for Freephone (800 numbers)
destination-pattern 908T
port 0/0/0:15
prefix 08
dial-peer voice 101 pots
description Call routing for Local Dialing
destination-pattern 9020[2-9].......
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 106 pots
destination-pattern 9[2-9].......
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 110 pots
description Call Routing for Operator
destination-pattern 9100
port 0/0/0:15
forward-digits 3
dial-peer voice 111 pots
description Call Routing for Services
destination-pattern 91..
port 0/0/0:15
forward-digits 3
dial-peer voice 112 pots
destination-pattern 918..
port 0/0/0:15
forward-digits 4
dial-peer voice 113 pots
description Call Routing for Directory Services
destination-pattern 9118...
port 0/0/0:15
forward-digits 6
dial-peer voice 114 pots
description Call Routing for Childline
destination-pattern 908001111
port 0/0/0:15
forward-digits 8
dial-peer voice 115 pots
description Call Routing for NHS Direct
destination-pattern 908454647
port 0/0/0:15
forward-digits 8
dial-peer voice 116 pots
description Call routing for Freephone (500 numbers)
destination-pattern 905T
port 0/0/0:15
prefix 05
dial-peer voice 117 pots
description Call routing for National Dialing
destination-pattern 901[2-9]........
direct-inward-dial
port 0/0/0:15
forward-digits 11
dial-peer voice 1 pots
preference 1
incoming called-number .
direct-inward-dial
port 0/3/0
dial-peer voice 180 voip
description Catchall VoIP Dial Peer
voice-class codec 1
voice-class h323 1
fax rate disable
fax protocol pass-through g711ulaw
no vad
did you add that station-id command? Also enable fax-relay..
HTH,
Chad
I have added the command, but no change. This not a fax relay from router to router. The call is being received by ISDN/E1 line in the router itself. Also, it is a G3 fax, which I have disabled the G3 on.
can you hook me up witha debug voip ccapi inout
please..
Chad
Here is the voip ccapi inout debug
246
