fxs not work for srst mode
When we do the srst test, we find fxs ports are not work. We get the busy tone when lift up the handset of analog phone. But, we get normal dial tone when we shut dial-peer voice 999200 pots. Is there any configuration error in below?
Our CCM is 4.1(3)sr3a and version of c2851 is 12.4(15)T1 and srst version is 4.1(0)
voice-port 2/0/0
description X5527 (FAX)
service mgcpapp
shutdown
port 2/0/0
ccm-manager fallback-mgcp
ccm-manager redundant-host 165.46.67.21
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server <publisher>
ccm-manager config
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7910 4
limit-dn 7935 4
limit-dn 7940 4
limit-dn 7960 20
limit-dn 7970 4
timeouts interdigit 5
ip source-address <ip addr> port 2000
max-ephones 90
max-dn 150 dual-line
system message primary Telephone Backup Mode
voicemail <mailbox nbr>
moh <filename>
multicast moh <ip addr> port 16384 route <ip addr>
time-format 24
Bronze
Re: fxs not work for srst mode
Try adding
application
global
service alternate Default
This is needed for MGCP to fall over and become an SRST (H323 Gateway).
Hope this helps, if so please rate.
Dave
Bronze
Also just looking into your config a little further your dial-peer is missing a destination pattern!
More info can be found in the following doc
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080144630.shtml
Hope this helps, if so please rate!
Dave
208
