FXS Port 0 has no dial tone FXS Port 1 has dial
     For some reason port 0 on my FXS card does not provide dialtone.  The settings on port 0 and port 1 are identical and I have swapped out analog phones
Symtoms
I can call the phone attached to port 0 from port 1 on the same card.
The LED associated with port 0 comes on when the phone goes off the hook.
On port 0 the phone goes off hook, on hook, then off everytime I pick up the phone.
Any Ideas
Everyone's tags (5)
1 ACCEPTED SOLUTION
Silver
Re: FXS Port 0 has no dial tone FXS Port 1 has dial
If you have "direct-inward-dial" configured under the FXO/FXS dial peers, remove them and try again.
MK
Silver
MK
Your solution worked, thank you.  Any ideas on how to get call through to the FXS ports directly using DID numbers? When I remove the DID command from the dial-peer and try to dial in I get a second dialtone.
Silver
Do you have connection plar configured under the voice port?
voice-port 0/1/0
connection plar 1234 (extension where the call will be terminated)
MK
I am running CME on both routers and I am trying to place a call from WYRT1 to AZRT1 through the national or international pots dial-peer to a FXS port on AZRT1 with multiple numbers
No commands have been entered under the FXS Port.  I wanted to point multiple numbers to this FXS port and I wasn't sure if PLAR would be able to do this
hostname WYRT1
...Limited output.....
dial-peer voice 8 pots
description NATIONAL CALLING
preference 1
destination-pattern 91..........
direct-inward-dial
port 3/0:23
forward-digits 10
dial-peer voice 9 pots
corlist outgoing INT
description INTERNATIONAL CALLING
preference 1
destination-pattern 9011T
direct-inward-dial
port 3/0:23
prefix 011
hostname AZRT1
preference 1
destination-pattern 91[29]..[29]......
direct-inward-dial
port 1/0:23
forward-digits 10
preference 1
direct-inward-dial
port 1/0:23
prefix 011
dial-peer voice 1 pots
preference 1
destination-pattern 7573683333
direct-inward-dial
port 2/0
forward-digits all
dial-peer voice 2 pots
preference 1
destination-pattern 0112223334444555
direct-inward-dial
port 2/0
forward-digits all
dial-peer voice 3 pots
preference 1
destination-pattern 7184415453
direct-inward-dial
port 2/0
forward-digits all
Silver
Replace the extension with "X".  If your extensions are 4 digits then use "Connection plar XXXX" under voice port. This will mach any 4 digits number.
voice-port x/y/z
connection plar XXXX opx
MK
Sorry for the delay in communication.
Thank you for the suggestion but I was trying to setup this port to have multiple different numbers which do not fall into any specific range.
Example  800-555-1212, 214-728-2839, 0112833782901 all point to fxs port 0/1.  I would like to have call routed through the PRI and the have the phone ring directly.
4223
