fxs port stuck
hi,
ios: Version 12.4(24)T8
cme: 7.1
VIC2-2FXS
I have an analog phone under voice-port 0/2/1
all works fine except sometimes when I call home from outside or when I try to use the phone from inside it doesn't work I have to do a shut and no shut of the interface.
when it doesn't work this is what I've been able to find,
#sh voice dsp
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP   DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g711ulaw      24.3.8 busy  idle      0  0 0/2/1     01    0     75867/26
                           *DSP SIGNALING CHANNELS*
C5510 001 01 {flex}        24.3.8 alloc idle      0  0 0/0/0     02    0         43/0
C5510 001 02 {flex}        24.3.8 alloc idle      0  0 0/0/1     06    0         36/0
C5510 001 03 {flex}        24.3.8 alloc idle      0  0 0/2/0     02    0         33/0
C5510 001 04 {flex}        24.3.8 alloc idle      0  0 0/2/1     02    0        766/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
RTR#sh voice call summary
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0         -          -  -                     FXOLS_ONHOOK
0/0/1         -          -  -                     FXOLS_ONHOOK
0/2/0         -          -  -                     FXSLS_ONHOOK
0/2/1         g711ulaw   n  S_SETUP_REQ_PROC      FXSLS_WAIT_OFFHOOK
the phone is not being used but it's s if it's hung the fxs card does not detect that the phone is not being used or something.
voice-port 0/2/1
 mwi
 cptone CA
 timeouts ringing infinity
 description *** HOME PHONE ***
 station-id name HOMEPHONE
 station-id number 41250
 caller-id enable
not sure if this is a bug or what. this happens maybe once every 2...3..4 weeks so it doesn't happen every day.
you think moving to IOS 15.0.1M8 will fix this? anyone else had the issue?
I could try to change the phone to the other FXS port but really worth it since this happens every 2...3..4 weeks.
ideas?
thanks.
Have you tested if
Have you tested if disconnecting the cable from the FXS port and plugging it back in also resolves?
hi,yes I have but it did not
hi,
yes I have but it did not work.
only way I found was to do a shut and no shut on the voice port.
here is the fix for others, I
I went from advipservices to same version of ios but the one called,
c2801-ipvoicek9-mz.151-4.M8.bin
now dsp has the good drivers and doesn't complain anymore.
C5510  001 01 {flex}       28.3.11 alloc idle      0  0 0/0/0     02    0         37/0
C5510  001 02 {flex}       28.3.11 alloc idle      0  0 0/0/1     06    0         37/0
C5510  001 03 {flex}       28.3.11 alloc idle      0  0 0/0/2     10    0         37/0
C5510  001 04 {flex}       28.3.11 alloc idle      0  0 0/0/3     14    0         37/0
153
