FXS port
Customer have CUCM 7.1 with E1 trunk with DID block 5xx - 699; now he is having 4 PSTN line 24466567X, he want to integrate these PSTN line with CUCM 7.1, do it possbile to have a IP Phone to ring for incoming call 24466567x..
Please light me the workaround for these.
1 ACCEPTED SOLUTION
Re: FXS port
Balamurugan,
              Yes it is possible for a PSTN line that is connected in a cisco voice gateway to directly ring an internal ip phones extension. A PSTN line that connects to a cisco voice gateway(2800 router for example) must use an FXO port, not FXS.  FXS is for end stations such as phones.  FXO ports connect to the PSTN.  You can use the plar command on the FXO voice-port, such as this.  The plar command sends any incomming call recieved on that voice-port to the extension in the connection plar command.
voice-port 0/0/0
connection plar 2000 ------> if someone calls the PSTN line connected to voice-port 0/0/0, then the voice gateway will send the call to extension 2000.
Jason
Re: FXS port
Balamurugan,
voice-port 0/0/0
Jason
Re: FXS port
Thanks a lot it is working....
198
