fxs ports state unknown cisco 1861
Hello ,
Cisco router 1861 the ports are unkown state .
I tried 'mgcp' 'no mgcp'
show ccm
Primary         Registered               172.26.4.2
First Backup    Backup Ready             172.26.4.1
Second Backup   None
Current active Call Manager:    172.26.4.2
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            09:44:49 UTC Dec 25 2013 (elapsed time: 00:00:13)
Last MGCP traffic time:         09:44:49 UTC Dec 25 2013 (elapsed time: 00:00:13)
Last failover time:             11:30:26 UTC Dec 22 2013 from (172.26.4.2)
Last switchback time:           11:31:11 UTC Dec 22 2013 from (172.26.4.1)
Switchback mode:                Immediate
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  04:54:21 UTC Dec 8 2013
Last MGCP Fallback end time:    11:25:42 UTC Dec 22 2013
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
FAX mode: disable
Configuration Error History:
store179#show mgcp endpoint
aaln/S0/SU0/0@store179
aaln/S0/SU0/1@store179
aaln/S0/SU0/2@store179
aaln/S0/SU0/3@store179
aaln/S0/SU1/1@store179
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxs-ls      up    dorm on-hook  idle     y
0/0/1           --  fxs-ls      up    dorm on-hook  idle     y
0/0/2           --  fxs-ls      up    dorm on-hook  idle     y
0/0/3           --  fxs-ls      up    dorm on-hook  idle     y
0/1/0           --  fxo-ls      up    down idle     off-hook y
I have dial-peers for the ports .
Any ideas ?
1 ACCEPTED SOLUTION
VIP Purple
Hi Ben,
Could not find any info related to the cause behind un-registration ?
In the meanwhile, can share the router config and try upgrading to latest firmware 15.1.3T4 , if possible?
regds,
aman
VIP Purple
Hi Ben,
what is the CUCM version u are using? can u share show version and show inventory from 1861 router.
I was seeing this bug:
CCMADmin page 6.1.1 says mgcp fxs port instead of sccp for sccp GW
CSCso31225
Adding cisco gateway 1861 and adding the VIC 3 FXS DID the port page says cisco mgcp fxs port
the port never registers to the call manager.
There is no workaround.
regds,
aman
Cucm version 8.5.1.13900-5
show version
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 15-Nov-10 20:58 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
store179 uptime is 2 weeks, 3 days, 5 hours, 36 minutes
System image file is "flash:c1861-advipservicesk9-mz.151-3.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C1861-SRST-F/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K bytes of memory.
Processor board ID FTX143780W3
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
12 User Licenses
10 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
128K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C1861-SRST-F/K9       FTX143780W3
show inventory
NAME: "C1861-SRST-F/K9 Chassis", DESCR: "C1861-SRST-F/K9 Chassis"
PID: C1861-SRST-F/K9   , VID: V02, SN: FTX143780W3 NAME: "C1861-SRST-F/K9 Chassis", DESCR: "C1861-SRST-F/K9 Chassis"
VIP Purple
Hi Ben,
regds,
aman
Is it possible to collect the debug while doing "no mgcp and mgcp"
Debug mgcp packets
debug mgcp events
debug mgcp error.
that would give us better idea on this issue.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Debug mgcp packets
*Dec 25 13:13:25.808: MGCP Packet sent to 172.26.4.2:2427--->
NTFY 257951726 *@store179.super-pharm.co.il MGCP 0.1
X: 0
O:
*Dec 25 13:13:25.820: MGCP Packet received from 172.26.4.2:2427--->
200 257951726
conf t
Enter configuration commands, one per line.  End with CNTL/Z.
store179(config)#no mgcp
WARNING: no mgcp: Teardown MGCP application may take a while to clean up resources
store179(config)#
*Dec 25 13:13:36.220: MGCP Packet sent to 172.26.4.2:2427--->
RSIP 257951727 *@store179.super-pharm.co.il MGCP 0.1
RM: graceful
RD: 0
*Dec 25 13:13:36.228: %MGCP_APP-6-MGCP_SHUTDOWN_COMPLETE: MGCP Shutdown has completed
mgcp
store179(config)#
*Dec 25 13:13:46.980: MGCP Packet sent to 172.26.4.2:2427--->
RSIP 257951729 *@store179.super-pharm.co.il MGCP 0.1
RM: restart
*Dec 25 13:13:47.004: MGCP Packet received from 172.26.4.2:2427--->
200 257951729
*Dec 25 13:13:47.008: MGCP Packet received from 172.26.4.2:2427--->
RQNT 34773851 AALN/S0/SU0/1@store179.super-pharm.co.il MGCP 0.1
X: 2
R: L/hd
Q: process,loop
*Dec 25 13:13:47.008: MGCP Packet sent to 172.26.4.2:2427--->
200 34773851 OK
RQNT 34773852 AALN/S0/SU0/2@store179.super-pharm.co.il MGCP 0.1
X: 2
R: L/hd
Q: process,loop
*Dec 25 13:13:47.012: MGCP Packet sent to 172.26.4.2:2427--->
200 34773852 OK
*Dec 25 13:13:47.012: MGCP Packet received from 172.26.4.2:2427--->
RQNT 34773853 AALN/S0/SU0/3@store179.super-pharm.co.il MGCP 0.1
X: 2
R: L/hd
Q: process,loop
200 34773853 OK
RQNT 34773854 AALN/S0/SU1/1@store179.super-pharm.co.il MGCP 0.1
X: 0
R: L/hd
Q: process,loop
*Dec 25 13:13:47.016: MGCP Packet sent to 172.26.4.2:2427--->
200 34773854 OK
*Dec 25 13:13:47.016: MGCP Packet received from 172.26.4.2:2427--->
RQNT 34773855 AALN/S0/SU0/0@store179.super-pharm.co.il MGCP 0.1
X: 2
R: L/hd
Q: process,loop
200 34773855 OK
*Dec 25 13:13:47.020: MGCP Packet sent to 172.26.4.2:2427--->
NTFY 257951731 *@store179.super-pharm.co.il MGCP 0.1
X: 0
O:
*Dec 25 13:13:47.020: MGCP Packet received from 172.26.4.2:2427--->
AUEP 34773856 AALN/S0/SU0/1@store179.super-pharm.co.il MGCP 0.1
F: X, A, I
*Dec 25 13:13:47.024: MGCP Packet sent to 172.26.4.2:2427--->
200 34773856
I:
X: 2
L: p:10-20, a:PCMU;PCMA;G.nX64, b:64, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:10-220, a:G.729;G.729a;G.729b, b:8, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:10-110, a:G.726-16;G.728, b:16, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:10-70, a:G.726-24, b:24, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:10-50, a:G.726-32, b:32, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:30-270, a:G.723.1-H;G.723;G.723.1a-H, b:6, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
L: p:30-330, a:G.723.1-L;G.723.1a-L, b:5, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:L;G;D;T;H
M: sendonly, recvonly, sendrecv, inactive, loopback, conttest, data, netwloop, netwtest
*Dec 25 13:13:47.024: MGCP Packet received from 172.26.4.2:2427--->
AUEP 34773857 AALN/S0/SU0/2@store179.super-pharm.co.il MGCP 0.1
F: X, A, I
200 34773857
I:
X: 2
*Dec 25 13:13:47.028: MGCP Packet received from 172.26.4.2:2427--->
AUEP 34773858 AALN/S0/SU0/3@store179.super-pharm.co.il MGCP 0.1
F: X, A, I
*Dec 25 13:13:47.028: MGCP Packet sent to 172.26.4.2:2427--->
200 34773858
I:
X: 2
AUEP 34773859 AALN/S0/SU1/1@store179.super-pharm.co.il MGCP 0.1
F: X, A, I
*Dec 25 13:13:47.032: MGCP Packet sent to 172.26.4.2:2427--->
200 34773859
I:
X: 0
*Dec 25 13:13:47.032: MGCP Packet received from 172.26.4.2:2427--->
AUEP 34773860 AALN/S0/SU0/0@store179.super-pharm.co.il MGCP 0.1
F: X, A, I
200 34773860
I:
X: 2
*Dec 25 13:13:47.036: MGCP Packet received from 172.26.4.2:2427--->
200 257951731
*Dec 25 13:13:48.004: MGCP Packet sent to 172.26.4.2:2427--->
RSIP 257951728 *@store179.super-pharm.co.il MGCP 0.1
RM: restart
*Dec 25 13:13:48.036: MGCP Packet received from 172.26.4.2:2427--->
200 257951728
store179(config)#
store179(config)#
store179(config)#
store179(config)#
store179(config)#
store179(config)#
store179(config)#u all
% Invalid input detected at '^' marker.
store179(config)#exit
store179#
*Dec 25 13:14:02.016: MGCP Packet sent to 172.26.4.2:2427--->
NTFY 257951732 *@store179.super-pharm.co.il MGCP 0.1
X: 0
O:
*Dec 25 13:14:02.032: MGCP Packet received from 172.26.4.2:2427--->
200 257951732
it's not possiable to do the other debugs they stuck the router
VIP Purple
Hi Ben,
Did u upgrade the router IOS and problem got resolved?
regds,
aman
No just
now it's on the pub
314
